The "Play with design software..." thread showed me the Z axis offset settings in XSim that was unaware of, so I tried to replicate a design I've been playing with in both programs to see how they compare. This is a 3 way with DCS165-4 woofer, RS52AN mid, and a ND20FB high. Both simulations are using the same FRD and ZMA files run through response modeler for the intended cabinet. The crossover values in PCD looked pretty good, decent but not awesome reverse nulls and flat response. The response was near identical in XSim, until I applied the offset delays, then it went a bit wonky. I noticed the "Polar Active" setting in WinPCD makes the curves far more similar with the same offset settings in both programs, are the Z offsets ignored until you activate the polar response?
The PCD image has an overlay without the polar active, while the black plot and phase is with polar active. The XSim plot is with the Z offsets. Note the response is similar but not exact, and the most obvious differences are in the system phase plot.
Follow up question... How do you guys typically model for phase tracking when designing on paper? It's obvious that Z offset has a huge effect on phase tracking, particularly at the higher frequency / shorter wavelength transition to the tweeter.
If using WinPCD, should I tweak with Polar Active, or should I use XSim to tweak?
