Do you ever do that thing where you want to experiment with something, but to do so, you need a bunch of other things in place, so you end up rigging a bunch of stuff to just get on with it and you end up experimenting with all the stuff you just rigged up as well? Well I just did that and was so surprised by all the various rigged elements that I had to post the experience.
So I've had a Minidsp I bought used from a forum member a couple of years ago and of course it has been on the shelf the whole time. I wanted to give it a try, so I jumped on line and purchased a plug in for $10, a little worried that the version would be incompatible (part of the reason I hadn't played with it yet). It downloaded fine and after a little messing around, I was up and running and could write to the Minidsp unit. Cool. Now I need a 4 channel amp and a 2 way speaker with no crossover.
I had posted before about the New Wave buyout speakers having perfect cutouts for the Seas L16RN-SL and the Seas H1212 tweeter which I had lying around. One speaker was already assembled with no crossover, so I finished the internal cabinet mods on the other one and installed the drivers. I plugged the ports as the box is only 1/3 cu ft and the Seas woofer wants a much larger vented enclosure. Cool.
I also had a Sure 4 x 100W amp (7498 chips) on the shelf that I picked up at the tent sale a couple years ago. I paid peanuts for it because one of the fan blades was missing. So I grabbed a 24V 5A power supply from a DTA-100 and fired it up. The fan spun up and the green light came on. Cool.
I had measured these drivers in this cabinet before, so I brought the files into PCD and applied all kinds of filters and delays to them in the active section until the FR was flat and the phase was tracking like a champ. It was sooooo much easier than applying the passive components. Once it looked good, I copied those parameters over to the Minidsp and loaded it up.
Now I got to hook everything up and hear the results of all my rigging. Cool.
It was outstanding right off the bat. With all these unknown variables in components and active xo process, I expected to have a disappointing first and maybe second impression right off the bat. Nope. It's not the best setup I've heard or even at my house, but for throwing old components from the shelf together with an undersized power supply and winging the xo, I was shocked how good it sounded. I knew the L16 has midrange distortion issues so I crossed at 1.5kHz and I think I missed most of it.
Then I pulled out the port plugs which left an 8dB peak at 90Hz! No problem, just dsp it flat and sync with the plug in. Then I shoved a smaller diameter, longer port right in the port hole (it was tapered and pressed in snug) to get the port to help with the lower frequencies and re-tuned with the Minidsp! So easy! So much fun!
So here's my wrap-up:
Sure 4 x 100W amp: Unbelievable for this application and the price. Very low noise floor and great dynamics, especially considering the PS was limiting the amp to probably 40W to each woofer and 10W to each tweeter.
Minidsp: I can't believe how easy this was to implement and how little it colored the sound. It literally takes seconds to implement a change as complex as you want and I heard no detriment adding large (>6dB) cuts or boosts. The $10 plug in had more than enough features to completely customize the 2-way speaker.
Seas L16RN-SL: This thing is a BEAST! I had no idea. It sits in a 5.75" diameter frame with an extra large cone stuffed in that space and a respectable 6mm xmax, but the xlim is 11mm and I'm pretty sure I went past that many times with nary a sound from the woofer. Holy moly - I couldn't hurt this thing. Zaph measured it as the lowest distortion woofer in it's category from 200Hz down and I totally believe it. Have you ever felt a palpable chest thump from a pair of 5" woofers at 8ft away? Me neither until now.
It's nice when every link in your rigged chain is stronger that you thought it would be!
Dan
Dan
