Of course the bass is touted as exceptional, but how good is the mid-range vs other highly rated $50 to $75 drivers, or the PE reference aluminum cones?
Anarchy Woofer
Originally posted by jclin4 View PostFace (Mike B) did exactly that. He used a waveguide on the tweeter to get a low XO point. I heard it at the NYDIY this summer and it was the best pair there IMO.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
I believe cjd did a 2.5-way with them and the big SB29. What I recall hearing was really impressive.
http://www.divine-audio.com/ansonica/
It won the "Design I'd like to have in my living room" at DIY Chicago 2011.
This led me to ponder a small 2 way with some great bass as well. I was going to try a on paper model using the data here: http://www.audioxpress.com/article/t...6-017r-anarchy
Think an RS28 tweet would make it low enough, with a notch on that woofer 4kHz breakup node?Electronics engineer, woofer enthusiast, and musician.
Wogg Music
Originally posted by wogg View PostThis led me to ponder a small 2 way with some great bass as well. I was going to try a on paper model using the data here: http://www.audioxpress.com/article/t...6-017r-anarchy
The peak at 4k is easily dealt with. Probably no more than a small value cap (.33uf or so) in parallel with the woofers inductor or possibly a small value inductor (.010 or so in series with the woofers parallel cap on a 2nd order electrical filter, will tank that nicely without the need for an additional node.
Originally posted by Beau View PostHong built a Anarchy based speaker.
Muy bueno.
It pounds nicely.
http://projectgallery.parts-express....he-renditions/Some people are addicted to Vicodin. I'm addicted to speaker building.
LM4780 Parallel Chipamp
Sonata Soundbar Project
I've used the Anarchy in two ways to 1200hz and 1800, it sounded fine in both speakers. They sound surprisingly good in sealed .5-.7cf enclosures. If you want to use ghem ported, tune low."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.diy-ny.com/
Originally posted by jclin4Face (Mike B) did exactly that. He used a waveguide on the tweeter to get a low XO point. I heard it at the NYDIY this summer and it was the best pair there IMO."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Originally posted by kevintomb View PostWhat kinda final SPL did you get after BSC?Electronics engineer, woofer enthusiast, and musician.
Wogg Music
Here are the graphs from the 2-way I did using the RS28.
