Originally posted by donradick
View Post
rpb, It's about four feet into a somewhat irregular ~22'x26' room with sloping ceiling; think upstairs loft.
---k---Your impulse response definitely doesn't look good. I'm guessing this is related to measurement gating. Bad measurements makes everything difficult.
I'd be interested in seeing the individual drivers frequency response before/after crossover.
Did you unibox the Paper drivers box sizes? I never have, so don't know if the paper need bigger boxes. Your boxes look so darn similar to mine, I don't know if you built differently from the original to accommodate the paper versions.
It be interesting to see off axis response and a overall power response to better understand the treble hot issue. Toeing in or out or room may alter your opinion.
Played around with channel delay and never gained much with the impulse response. Key word ... played.
Read Bagby's white paper on measurement technique, sorry guys, it's above my head. Learning guys, maybe someday ... Did figure out how to gate the response and how to find where the first reflections appear in the impulse response. Hopefully, the next graphs should be gated correctly.
Would the individual driver response be ok from the same @1m, on tweeter position, or explain what you'd like and how, I'll give it a shot.
Yes, I did unibox the paper and metal woofers. IIRC, they were fairly close. Will try and find that, and post later.
The outer dimensions are the same as the Statement II, but the mid's enclosure changes the internal woofer volume. To me, the paper woofers looked fine in the larger box, and the cut sheet sealed the deal. No matter how many times I do the math, measure, and cut, I always screw some part of that up. Sooner or later, I'll get the dimensions up.
