And please don't forget to read Charlie Laub's excellent guide on how to generate FRD files for your drivers using the ARTA module. Once you know how to obtain T/S parameters, model your box, generate ZMA and FRD files, crossover modeling is just a few steps away. It's very difficult to help newcomers without good data, but when you have a good set of measurements, everyone here can help you put together a great sounding system that you can call your own.
Easy ZMA and T/S Parameters Using The LIMP Module in ARTA - An Illustrated Guide
This is a sticky topic.
Some people are addicted to Vicodin. I'm addicted to speaker building.
The Chorales - Usher 8945A/Vifa XT25TG Build
ESP Project 101 Lateral MOSFET Amplifier
LM4780 Parallel Chipamp
Sonata Soundbar Project
The Renditions - Active/Passive Towers -
https://www.jfcomponents.com/product...range-mid-bass
https://www.jfcomponents.com/product...um-cone-wooferComment
You've got to love the grin on that face...Some people are addicted to Vicodin. I'm addicted to speaker building.
The Renditions - Active/Passive TowersComment
This is Great, Thanks!!
I'd be even better if somebody contributed with the ARTA Switch Box Illustrated Guide for newbies like meComment
Hi all,
I want to thank again for this great post and I´m hoping somebody can clarify something for me, I bougth some drivers that are rolling around on Amazon and Ebay and I´m using the jig to measure them but the results are not smooth as I usually see them, is that OK or am I doing something wrong? Please see picture.
Thanks,
AlexComment
I had that happen three times. First time was the original POS Dayton Woofer Tester 3, second and third times were both bad USB sound cards. My original self-contained jig using an inexpensive Ebay sourced USB card gave up the ghost and started doing that same thing. The last time was when I tried using a Behringer UMC202HD which was a noisy POS.
I switched to a Creative X-Fi USB model and that thing is squeaky clean from 10Hz to well over 40K.Don't listen to me - I have not sold any $150,000 speakers.
I had that happen three times. First time was the original POS Dayton Woofer Tester 3, second and third times were both bad USB sound cards. My original self-contained jig using an inexpensive Ebay sourced USB card gave up the ghost and started doing that same thing. The last time was when I tried using a Behringer UMC202HD which was a noisy POS. I switched to a Creative X-Fi USB model and that thing is squeaky clean from 10Hz to well over 40K.
So, I do have a problem then, I will try another computer and see how that goes.Last edited by AlexRivera; 06-25-2017, 10:12 AM.Comment
Another question for the experts, so if the "100" Ohms resistor ended up being a 98.9 Ohms resistor do I need to adjust something else or enter some compensation value somewhere?Comment
Last edited by hongrn; 06-29-2017, 07:20 PM.Some people are addicted to Vicodin. I'm addicted to speaker building.
Awesome Thanks Hong!!!Comment
Calibration question... it's not clear if cal is done with output looped to input (that's what LIMP seems to say) or with the jig plugged in but not connected to anything on the test clips. Which is it?
I fought this crap for four days getting nowhere. I built a jig per diagrams but it would. not. work. for anything. All I got was two nearly straight horizontal lines. Tried 3 different laptops with WDM and ASIO drivers, my desktop with a good Xonar DG card, and then the onboard sound on the desktop. No go on all. Didn't start working until I went to Measurement Setup > Measurement config > Reference channel > and changed from the default Right, to Left. All of a sudden it's giving plausible results. What did I do wrong?Comment
Calibration is explained in post number 6. Please try to read the entire thread and follow the instructions.Some people are addicted to Vicodin. I'm addicted to speaker building.
