Design Team Build: The Boomsticks - 2.5 way tower with 4 x RS100-8 and ND25F
  • #16
    Originally posted by donradick
    FUN TIMES! Wow, that looks like what I've been thinking about - lots of medium size woofers in a small tower. I'm sort of leaning towards the RS paper drivers. BTW, very terrific intro to the build thread. This forum needs a little humor. re: "unobtrusive" Can't deny that many, many woman like skinny speakers.
    The paper versions would probably work equally well, just a bit less bass. But you will gain a bit more sensitivity.
    -Kerry
    • #17
      Glad people appreciate the Army of Darkness quote. Wasn't sure if everyone would get it.
      -Kerry
      • #18
        How are you going to get RS100s to hit 40Hz?
        • #19
          Sketchup is the most easy to use and notuch learning curve, but falls apart for anything other than basic shapes. F360 seems to have more capability, but has a steeper learning curve. Sketchup is most frequently used, but with the option to export to dxf, it can be imported to vectric or other cad/cam program. A special add-on needs to be installed on the free sketchup for dxf support.
          • #20
            Have rs100p-8, RS 100-4 and rs100-8s, but couldn't get anything to 40s.
            • #21
              Measurements, after assembly, will answer any questions.
              Kenny
              http://www.diy-ny.com/
              • #22
                I clicked on this thread because of the AoD reference. Nice design. I assume these will be painted a circa '73 beige/puke color?
                • #23
                  Whoa! Deja vu. I love the concept. Please carry on.
                  • #24
                    What did you call those again, Richard? I can't remember the name...
                    • #25
                      Mid 40s - MLTL ?
                      • #26
                        Not 40, but 40s. I thought it was mid 40s but it's actually upper 40s. Obviously this not the most optimal alignment for flat response, but it should still sound ok and I couldn't pass up the opportunity to try. I could always go back and shorten the port later if it doesn't sound OK. Here is the box model and excursion at 20 watts input power.
                        [ATTACH=CONFIG]n1315385[/ATTACH]
                        -Kerry
                        • #27
                          Interesting excursion plot - most all of my vented sims exceed xmax below Fb.
                          did you do something different to get it flat like that?
                          Tangband W6-sub
                          • #28
                            I think it's just the motor on these. I've seen this on other woofers I've modeled before but it's not common. I checked to make sure I didn't have any filters on again and nothing is enabled but I didn't try any other programs. I can't get Unibox to work in my current version of Excel.
                            -Kerry
                            • #29
                              I couldn't stand the ambiguity, so I ran Unibox for 4 woofers, series/parallel connection.
                              Not exactly what you got, but a very,very attractive alignment.
                              Tuning even lower (I tried 45 Hz also) gives more of an EBS alignment, with max excursion only exceeded below about 38Hz
                              Adding 15% to published xmax (as shown below) with your tuning shows xmax exceeded only below 44 Hz.
Name:	4xRS100-8-19Liters 53Hz FB params.PNG
Name:	4xRS100-8-19Liters 53Hz FB MAX SPL.PNG
Name:	4xRS100-8-19Liters 53Hz FB excursion.PNG
                              Tangband W6-sub
                              • #30
                                Will be following this closely. I have been wanting to do something similar to upgrade from my Cinderella's. My thought was a 2.5 way in a MTMWWWW configuration.
