Not sure is this is allowed to ask about these PEDT designs but could this be converted to a in wall/ zero BSC XO? If This is not allowed, mods please delete.
Design Team Build: The Boomsticks - 2.5 way tower with 4 x RS100-8 and ND25F
Originally posted by Wolf View PostI would give you photo examples if photobucket was cooperating, BUT- you might have better luck tomorrow....
At my sig, projects listed on the left. Combinations listed below...
Krylon hammered black under red for my Sophomores. The black here is more of a charcoal tone. This came out blood-red, and one of my favorite finishes.
Krylon hammered silver under blue for the Tesseracts. Metallic blue for sure here.
Rustoleum hammered black under purple for the Xenoliths. The black is actually black for this one. This makes a rich dark purple.
You don't have to use the recommended basecoat, as the Metalcast colors lay on most any solid color underneath. The MC colors are translucent, so they take on the color tone of the color below. I've also used the Krylon Metal X red and blue, and even though they are made by the same parent company, the Duplicolor works better.
I recommend only using 2 coats of the metalcast products for coverage. If you start to lay it on thicker, it'll develop a bit of haze and the transparency will become a bit milky. I recommend using spray polycrylic or any acrylic clear over top to protect it. I would do a sample piece first to know how you want to apply it.
Do not use lacquer clear-coat if you don't want the finish to change. I applied the red on plexiglass once to make it a transparent red panel. I hit that with Minwax clear gloss lacquer to finish it, and it changed the entire surface to look very close to that of stained glass. I don't know if the effect would be different on a different substrate.
These panels were used on the rear of the '2i' project as a xover installation door. Photos are also in the bucket.
Hope this helps,
Wolf-Kerry
Originally posted by manu et deo View PostNot sure is this is allowed to ask about these PEDT designs but could this be converted to a in wall/ zero BSC XO? If This is not allowed, mods please delete.-Kerry
When you say you are worried it is going to show through, are you referring to the texture? Could it be wet sanded before top coating if it's a texture problem?
Originally posted by Kevin K. View PostWhen you say you are worried it is going to show through, are you referring to the texture? Could it be wet sanded before top coating if it's a texture problem?
It's hard to explain. You know how if you are spraying gloss paint from a spray can, you can get just a bit of of the overspray causing lines in your paint making some parts look really glossy and some parts dull. It is kind of like that I think. You can see how different shades of silver are showing up in the picture. There is no texture to the paint per se. It all feels smooth. But I can't get it to be one consistent color. The Duplicolor Metalcast is semi-translucent - it acts like a pearl or candy coat - so I'm worried that the shading will show through the Metalcast coat.
Anyway, I did a couple test pieces and the orange doesn't have the look I want. The red looks good, but I shot a coat of orange over the red and that looks like the way I'll be going. Produces a nice, complex color that changes slightly based on the lighting.-Kerry
Those are looking really nice Kerry!
Are you planning to polish also or just wet sand? Will the bases be the same color or a high gloss black?
S.E.X.A.Y.
Love it. Love love love it.Builds - C-Killa - Speedsters - LithMTM - Talking Sticks - Pocket Rockets - Khanspires - Dayton RS Center - RS225/28A - Kairos - Adelphos - SEOS TD12X - Dayton 8 - Needles - 871S - eD6c - Overnight Sensations - Tritrix (ported) - Lineup F4 - Stentorians - The Cheapies - Tub Thumpers - Barbells - Tuba HT - Numerous subwoofers - probably missing a few...... :p
