Anyone? CNC mills or possibly a laser cutter.
  • Anyone? CNC mills or possibly a laser cutter.
    CNC mills or possibly a laser cutter, or maybe I need a machinist. I have borrowed an idea for speaker feet, but it requires using 7075 aluminum. Very small 2" X 1/2" discs with a small bowl in the center. I can't seemed to get any response from local people here. And, of course, I am willing to pay.
    Thanks for any suggestions,
    Robert
    -Robert
    So you need 2" diameter discs x1/2" thick, with a bowl shape taken out from the center on one side of the disc?
      That is correct. I have the specs with the particulars. The actual disc does not have to be polished, just the inside bowl, which is very shallow. 6-12 depending on the price and I can get the 7075 if necessary.
      Thanks, Robert
      -Robert
        Did you see the aluminum spacers that Kerry linked in his thread about the Boomsticks? they were at fab-worxinc.com under chassis parts, aluminum spacers.
          Yep, sure did. However, Kevin did not have the proper equipment to cut these.
          Thanks, Robert
          -Robert
            If no one closer to you can help you out I sure will.
              Dstebner...PM sent...
              -Robert
