A while ago someone took a measurement of some speakers, tuned them 90 degrees and took another measurement (It was in a garage IIRC). I'm pretty sure the 90 degree measurement was down around 6db all the way down to the lowest frequencies (It was a long time ago though, so I could be wrong)
Has anyone measured a ported speaker, turned It 90 degrees and taken another measurement? Just wondered If port output would be down relative to the driver output If you put a port In the side?. If It made no difference where you put the port, the port output should stay at the same level when you turn the speaker 90 degrees but the higher frequencies should drop.
Yes I know low frequencies are omnidirectional and It shouldn't make any difference but has anyone actually taken some measurements to prove this fact?
