Synergy horn build
  • jhollander
    No not really it's a pretty tight fit so there not much room. There's is minimal effect on the response.
  • shrub0
    John, Is there any guidelines to centering the midrange and woofers over the holes they fire into?
  • shrub0
    Thanks again John!
  • jhollander
    On page 7 of the drawing PDF, page 15 or the write up. I've also attached a picture
  • shrub0
    John, I'm preparing to cut the side panels of the horn. I see in the plans both ends should have 45 degree bevels but what is the length of the side panel? Click image for larger version
Name:	Annotation 2020-04-05 232049.jpg
  • jhollander
    Doesn't model like a BP6 as the port is to short. The volume in front of the woofer does change the response but as I recall it's out of the pass band.
  • shrub0
    John, will using a 3/4” inch woofer spacing ring negatively effect the woofer response? Is the woofer seeing a bp6 loading since there are ports on each side?
  • jhollander
    For the port mounting blocks, not exactly, I think I started with 3 inch and cut them down. You can also use wood mount blocks and epoxy in the first piece of pvc pipe
  • shrub0
    John, do you remember what size the pvc mounting blocks are?
  • jhollander
    Yes, exactly. As I mentioned in post 133 this is easier to do when the hold down board extends to the saw blade
  • shrub0
    Ok John, I finally understand, thanks for your patience. So when using the relief cut jig do I just line it up so that the saw will just fully cut the 22 degree angle and not reduce the width anymore then needed?
  • jhollander
    Yes that shows the 22 degree relief cut.
  • shrub0
    Or is the 22 degree bevel shown in this picture in pink.Click image for larger version
Name:	side panel bevel.jpg
  • jhollander
    No, the purple line is the 45 degree angle you cut before you started using the jigs. The jig in your picture is the 22 degree relief cut jig. A better version of this jig has the hold down board extending al the way to the saw blade.
  • shrub0
    Ok I think the source of my confusion is this picture. Should'nt we be cutting the purple line at 22 degress?
