Any plans to code for IOS?
2.1 amp with DSP -- preview/teaser
Originally posted by jwjarch View PostAny plans to code for IOS?
I may try an IOS client using Visual Studio sometime in the future, but right now it's not on my short list. With a more robust app you could have a lot more control over the DSP. For example, instead of using one of the 9 "pre-set" EQ frequencies and 11 gain settings, you could specify any frequency and any gain.
Originally posted by ttan98 View PostNeil,
How is your ADAU1701 DSP board differs from that produced by Sure Electronics? Is your s/w to to drive the DSP where does it come from, and is it the same as that used by Sure electronics?
The software I'm using is an outgrowth of software I started writing about 15 years ago for the TAS3004. There is also a version for the STA326 series and the larger STA308a series, all written in 6801 assembly code. The code is intended to work with a wide range of DSP chips, including the ADAU1701. There is a companion PC application for designing multi-way loudspeakers and that provides real-time control of the DSP and allows loading any ADAU1701 program developed with SigmStudio.
Recently I translated all of the microprocessor code to the Arduino environment and added a local user interface for the ADAU1701. That allows using an LCD display to select crossovers and other DSP features without an external PC. If I end up making a version of the plate amp with the Sure board, I won't use any of their "software". They provide a program for the ADAU1701 that implements a variable subwoofer filter, but it is isn't much code and it's not very useful for this application.
I certain can appreciate the considerations stated in Post #30. -but testing them and tweaking the parameters and evaluating the results could take a while. If someone wants to help, this could get done a lot quicker. I've got extra hardware that I could give away to someone willing to test and evaluate.
Honestly, I'm still agonizing over how much code I really want to put in public domainLast edited by Sydney; 06-17-2017, 12:39 PM."Not a Speaker Designer - Not even on the Internet"
Originally posted by Sydney View PostI certain can appreciate the considerations stated in Post #30.
Nonetheless, the Sure board is only $20. The chip itself sells for $11 in small quantities, and with the connectors, PCB and supporting parts this board would cost me about $35 in parts alone. Assembly with enough beer to finish the job would double that cost. So it makes sense to see if this board can be used, even with those odd design decisions. As I said, I'll probably try it, since I already have the parts I need, but it might not prove to be a good approach.Free Passive Speaker Designer Lite (PSD-Lite) -- http://www.audiodevelopers.com/Softw...Lite/setup.exe
Originally posted by neildavis View PostI think you mean #32,....but testing them and tweaking the parameters and evaluating the results could take a while. If someone wants to help, this could get done a lot quicker. I've got extra hardware that I could give away to someone willing to test and evaluate.
Originally posted by Sydney View PostNo this:
Pardon the ambiguity
Regarding the code...I've benefitted from some of the open source code and I'm sympathetic to making some or even a lot of this DSP code freely available. But, it's been a lot of work, and at this point I'd prefer to keep this code "among friends", especially anyone willing to help, by testing, contributing or evaluating. I keep thinking about ways to give away some of it while protecting other parts, and I think eventually I'll find a balance I'm happy with. Right now I don't have a plan, but I'm working on it.Free Passive Speaker Designer Lite (PSD-Lite) -- http://www.audiodevelopers.com/Softw...Lite/setup.exe
Originally posted by neildavis View Post... and I think eventually I'll find a balance I'm happy with. Right now I don't have a plan, but I'm working on it.
While I'm not in a position to do so; what would prospective tester(s) require?
Originally posted by neildavis View Post... The only requirements for the tester would be a powered subwoofer, preferable one that is small, and some time to play with the different bass enhancement algorithms. I need to think about this some more, but it's got some potential for making the Act 4 phase an interesting "community" project.
Think on
