Very Simple Question. Is it worth replacing a $9.00 Steel Laminate Inductor with a $23-32 Air Core Induction that is in-line with midwoofers?
Steel Laminate is 0.22 ohms DCR. System impedance is probably close to 4 ohms minimum.
14 gauge Air-core is $23-32 and has a DCR of 0.32 ohms. Now this isn't a huge difference, but when you add in the other inductor the DCR of 0.26 ohms it becomes a fairly large portion of the DCR and I've heard some people say no more than 5% is allowable. I know that the inductors used were the ones modeled, and changing either of these inductors would change the response in some way - not as the designer intended. So I guess I have 2 questions.
1) Is going from 0.22 ohms to 0.32 ohms (or 0.43 ohms for 16-gauge) for a 4-ohm nominal design going to have a significant effect on the crossover / overall sound?
2) Is upgrading from a steel-laminate to air-core inductor going to cause a real and noticeable improvement in sound quality?
I saw this paper that said for lower frequencies, steel laminate was actually better suited-
http://www.die.ing.unibo.it/pers/gra...ers/ciep00.pdf
I've read the biggest issue with steel laminate, iron core, ferrite core type inductors is that if the core saturates, they experience hysteresis which greatly increases distortion. But I'm not sure if that's an incremental issue or more of a binary one. I am also not sure at what power level an inductor would reach hysteresis.
I've noticed that most high-end designs use 100% air core inductors, but the DCR of those air-cores has been properly factored into the crossover during the initial design, so that's not necessarily comparable.
ETA: I would ask the designer but Jeff Bagby has PMs turned off and I think he is trying to reduce the number of messages he gets.
