Thanks again for the files, John.
After reviewing your model and blended frds, I think I have found two big mistakes that I have made, one of which may be a contributing factor to the matchiing problem you are experiencing (sorry about that). When I initally started taking my on-axis measurements, I put the loudspeaker up on my horizontal polar response turntable, which raised the center of the woofer 25.25 inches above the floor. At an OmniMic distance of 39 inches and height of 55.375 inches (on tweeter axis) this created a large floor bounce reflection at 133Hz. So I removed the turntable and set the speaker on the floor for all on-axis measurements (mic 37.6 inches above floor at a distance of 39 inches). This helped to eliminate the floor bounce.
But putting the speaker on the floor was a big mistake on my part. With the speaker on the floor, the center of the woofer is only 7.5 inches above the floor. This near floor placement creates early reflections that completely invalidate the "W alone.frd" file that I posted in #131 above. And the T+W.frd, M+W.frd, and T+M+W.frd files that I posted in #132 are invalid for the same reason. This was probably a contributing factor to why you could not get a good match!
This next week I am going to place the speaker up on a 25 inch high stand that has an open frame below it. I will then re-measure all of the on-axis FRD's, using the bass removed track for the tweeter instead of the cap, and post the results. On this stand, the center of the woofer will be 32.5" above the floor. The tweeter/mic to floor height will then be 62.6", which is OK because the ceiling in this room is sloped and is 144 inches above the floor at this point.
The other big mistake that I am making is that I am trying to do my design using the raw OmniMic FF files alone, without using NF data, the blender, or minimum phase data. In comparing our files, it is obvious that my model is lacking significant BSC compared to yours. One of my problems is that I do not have excel and it is difficult for me to run the blender in open office. But, since my last failed attempt to use the blender, I have now developed some "workaround" procedures to extract the diffraction models from the blender. After adding the files together, I can blend them in OmniMic and extract minimum phase in XSim.
So it is back to the drawing board. Two steps backwards. One step forward. But a very good learning experience!!!! Thanks for all the excellent feedback!!!
