I don't think you understand the circuit layout. The battery (if used) (+) terminal is connected through a 1Mohm resistor to the node between the caps. The battery (-) terminal attaches at ground of the xover network. The voltage is only joined at the one side of each of the series capacitors' plates. The battery does not go across a capacitor as some on-line circuits show.
What Bill is doing, sans battery, is applying an 18VDC voltage to the caps' center node and the ground of the xover network. Upon removal, there is no resistance to rapidly discharge the voltage on the inner plates. It is therefore a long discharge time.
