Does this work for a three-way?? (Paging Jeff Bagby)
  • Does this work for a three-way?? (Paging Jeff Bagby)
    Hello,
    Call me an optimist, if you like!
    Reading this thread:
    http://techtalk.parts-express.com/fo...revisited-pics
    Perry Mason talking to his dentist:
    That order arrangement works well for flat baffle arranged drivers a good portion of the time. One order difference introduces the extra phase rotation to align the phase.
      That "rule of thumb" isn't necessarily a good one. You have to consider the behavior of the drivers in their overlap region. For example, if you have a cone mid that offers smooth extension to 100Hz, applying a 3rd order HP filter may or may not result in a 4th order slope at the XO point with the woofer.
      I've used 2nd order on the woofer, 1st on the mid HP, 2nd on the mid LP and 2nd on the tweeter HP resulting in LR2, LR4 slopes.
        But IF you stick to Acoustic slopes and design the XOs to meet the targets?
        Regards// Lasse
          Nothing to disagree with there!
          I was referring to electrical slopes, Lasse.
          If you stick to acoustic slopes, then the ROT really doesn't apply anyway as the model progresses.
            Hello Wolf,
            I was under the impression that all of this topic was about acoustic slopes and orders. Please correct me if I have misunderstood something here.
            What does "ROT" mean?
            Regards//lasse
              Originally posted by lasse View Post
              Hello Wolf,
              Regards//lasse
              ROT . . . Rule of Thumb.
              It is about acoustic slopes. But mixing them when acoustic offsets are minimal with respect to the wavelengths involved is not a good idea. For example, at 300Hz, the acoustic offset between a woofer and midrange on a flat baffle will only be a tiny fraction of the wavelength involved. In that case, a 2nd order slope on the woofer would not sum properly with a third order slope on the mid. You'd really want the same slopes for both.
                Agreed.
                    I personally like 2nd order transitions but that's not always possible at the higher frequencies. Using drivers with extended frequency responses and large overlap regions, 2nd order XOs are possible using few components, but you really need to have acoustically aligned mids and tweeters to pull it off. If they aren't, 4th order on the mid-tweeter XO with slope mixing can make it all work.
