Originally posted by Wushuliu
View Post
Is my Phase too fat?
Originally posted by dcibel View PostYou'll probably be happy with what you have, though you might consider adding an LCR filter to address the lump in the 2.5k to 3.5k region. The region just above the crossover freq will have a wide directivity compared to the frequencies below the crossover due to the transition from the woofer to tweeter. I find that lowering the level here often makes the sound more natural, basically you are compensating for the overall radiated energy (power response).
You will see something to this effect in Troels SBA-10:
I have used the original SB STC25 tweeter and now have the STC26 in its place. In my auditioning I tested it LR4 @1500Hz and higher. I detected no audible stress, but extended use might show a heat problem. I ended up using the LR4 @2K. It's part of my design hosted by Zaph. He provided the drivers and requested that I post a design. I took that a step further and documented the design and build fairly thoroughly. That was eight years ago!
The Chameleons
dlr
JeffB: "I've said this a number of times in discussions about my Kairos, but the Satori can cross lower naturally (without the aid of waveguide) than any other tweeter I have used"
Troels: "from my SBA-10 construction I learned the TW29RN can go really low without problems."
Originally posted by xmax View PostYou see even the much cheaper Seas (and the Transducer Labs) has a lot less distortion at 1K.
The SB tweeters are some of the best but I would never cross them below 3K at 12 or more dB
per octave.
Here's the TW29 soft dome:
http://www.audioxpress.com/article/t...gh-end-tweeter
And here's the Be edition:
http://www.audioxpress.com/article/t...m-dome-tweeter
You have increasing distortion below 2kHz, but it is purely 2nd order. I wouldn't hesitate to use the TW29 with a 2nd order 2kHz crossover, 4th order acoustic rolloff, but no lower.
Huh, I thought one of their advantages was that they could be crossed low.
Can't cross below 3k?
per octave.
Which version TW29? None of them like to go that low, they have a natural roll off that starts around 4K,
but then a large peak at around 1500, even if you get decent measurement it will not sound very good.
Also what are you basing your cap/coil ratios on?
All the SB stuff can sound fantastic but the tweeters can get naughty below 2K if not very sharply
filtered.
Originally posted by Wushuliu View Post
Yeah, but I have the LCR parts on hand and just kept them there as part of the learning experience.
@decibel, will do.
