Originally posted by donradick
View Post
Pretty Persuasions - InDIY Coax Build Thread
Originally posted by Millstonemike View PostJavad, I'm a novice at serious woodworking. And being that, left on my own, I would have filled the kerfs with wood glue prior to bending into shape - well not completely and wiping up after the bend. As I'm sure you know, the glue joints on softer wood are stronger than the wood itself. What do you think? Some got ya' as to why you shouldn't?--
Javad Shadzi
Bay Area, CA
https://youtu.be/j-bqIJalovo
And all glued and finalized braces Detail of the mid enclosure
The end caps are spaced 1/8 from the eventual top/bottom for some CLD treatment
Thanks!
Javad--
Javad Shadzi
Bay Area, CA
- Likes 3
Originally posted by JavadS View Post
Each brace was cut out with a jig saw and finalized to shape in my Wen desk top oscillating sander (love it btw!)
Keep up the great work! I'll be even more excited to hear these in April!
- Likes 1
Man, if I ever come to California, and visit you, and we're listening to music, and there is an earthquake..... I am for sure going to hide under a few of your speakers for safety... you build them like tanks!
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Originally posted by tomzarbo View PostMan, if I ever come to California, and visit you, and we're listening to music, and there is an earthquake..... I am for sure going to hide under a few of your speakers for safety... you build them like tanks!
TomZ
Javad--
Javad Shadzi
Bay Area, CA
Originally posted by JavadS View PostGood thing is they won't be that heavy so they'll be easily transportable, thanks for following!
Javad
Time to install some drivers!
This is the layout
As Ive done before, this is the process for an odd shaped driver Template.
First protect your driver and screw it down to a sacrificial MDF panel, 1/2 works great.
Next with a perfectly centered router base, trace around the frame with a 1/4 spiral bit, put an even layer of masking tape around the driver frame to slightly over size the template
Now on a new sacrificial piece, trace around the inside of the first sacrificial Template
This leaves you with a template 1/4 oversized
Now using a 3/4 Templating fixture, trace around the second sacrificial template to get the final template perfectly sized to the driver
With centering reference lines it is quick and easy to align the fixture on your baffle
Here is a quick blog describing the process: https://youtu.be/q5hltXG6X-Y
Here we have two enclosures ready to destroy, I mean flush mount drivers in! =)
Test cuts finalizing OD, ID and recesses
Marked and ready to go with logic check tracings
Midrange ID cut
8 recess and cutout
Position driver exactly where it needs to go, install fishing line in driver holes
Now with double sided tape on template, slide it over the driver frame and attach it firmly, then pull the driver out. This process perfectly positions the template centered around the driver cutout
Flush trim bit
And router
Test fit
Next port tube routering.
Thanks!
Javad--
Javad Shadzi
Bay Area, CA
- Likes 2
