New Peerless Tweeter
  • fdieck
    Originally posted by xmax View Post
    This is new RST vs the old RS (blue)Click image for larger version Name:	RST sv RS.jpg Views:	1 Size:	257.4 KB ID:	1376417
    Is the solid 2nd and the dashed 3rd harmonic?
  • xmax
    Originally posted by ani_101 View Post
    I had a pretty tough time working with that tweeter FR and took quite a bit of parts to shape it. Have it crossed at around 1500 /1600 to RS225P
    4 parts got it +/- 1ish for me with this circuit It met the midbass around 1500 and you can change the resistor value to shape the bottom range of the pass band.
    Keep in mind there was a healthy 4 ohm L-pad in the circuit flattening the impedance.   Click image for larger version  Name:	WC HP2.jpg Views:	1 Size:	702.8 KB ID:	1376421Click image for larger version  Name:	2-20.jpg Views:	1 Size:	58.4 KB ID:	1376422
  • xmax
  • xmax
    Hmm I already posted once. I will try again. This is the Peer TX vs the new Dayton RST.
  • fdieck
  • xmax
    Click image for larger version  Name:	VIA F SPEC.jpg Views:	1 Size:	164.3 KB ID:	1376404Click image for larger version  Name:	Viawave FR.jpg Views:	1 Size:	530.5 KB ID:	1376405
    I inquired through my Tymphany contact, but have not received a reply yet. I was hoping to get the manufacturer's HD plot.
  • olu78
    Any distortion measurements yet? Sent from my SM-G935T using Tapatalk
  • xmax
    Mounting flange is 4.135" X 3.186".
  • xmax
    Look at post #21, let me know if you still need a spec.
  • Pete Schumacher
    I used 8 parts on the 1300Hz XO for Apollo. Series padding resistor, damped 3rd order HP and then LCR EQ.
  • ani_101
  • dcibel
    This is good to know! I have a pair of the TW030WA11 in a box waiting to be used, the current plan is with a pair of Dayton PM220 so the crossover is intended to be <2kHz. I went with the TW030WA11 from the excellent test result by AudioXpress, though they only tested HD to 2kHz, the off-axis performance was excellent from the small waveguide.
  • dcibel
    Nice looking tweeter, I have to laugh a bit at that heatsink though, it's 99.9% cosmetic on a tweeter with ferrite motor.
  • augerpro
    What waveguide will you attempt to fit it to? I'm looking to build a hifi waveguide two way soon, so I am following with great interest.
    I'll design one and have it printed.
    Xmax> can you take the face shield off?
