New Peerless Tweeter
I've got a waveguide printed out and just waiting for a replacement tweeter - i was careless and dented the dome on the one I had. PE lists new ones as shipping in November. I'll post results in my 3D printed waveguide thread.
An easily removable face plate and nice flat mounting surface make this tweeter a no-brainer for waveguide application. If Tymphany had a factory made option, or even a pre-designed 3D printable model that would simplify things even further for the DIYer.
the faceplates are stainless steel, so that they can be thin enough to give the acoustic performance we are looking for, but still be strong enough,
and yes, there are no additional magnets holding the grille,
they work well in waveguides, these was designed to measure well in a totally flat thin faceplate, which means a (hard to achieve) raw response, as it's 'adjusted' by the faceplate/chamfer loading,
this flat raw response, means that you get a very honest performance in a waveguide, largely determined by the WG, rather than the anomalies of the TW FR + WG interaction.
- Likes 1
I thought they were steel but my magnet does not stick to them. There must be enough of a magnet behind the face plate to hold the grill on.
- Likes 1
According to the blurb from the manufacturer, they are steel faces.
Some da25’s I cut down to get closer to the woofer. The plate seems to be aircraft aluminum. At first I thought it was steel because it’s very strong for its thinness. These will be rear mounted and a small wave guide to be done. Not sure if I’ll do a simple 45 degree chamfer or round over. I’ll have a spare test piece I was going to try both and see which is better.1 Photo
It's not all that strange. A lot of SS domes are done this way.
Originally posted by ecj View PostThere was a bit of excess surround glue that stuck to one side of the faceplate but the faceplate didn't appear to be intentionally glued down, at least on the tweeter I opened. I'd imagine the surround could lift off the carrier if the faceplate was stuck to it all the way around.
If not the WG can be modded to work anyway.
Originally posted by ecj View PostFew pics for those interested, the faceplate aperture is 35mm and the grill diameter is 40mm. The cast faceplate is very thin at 1.5mm but seems rigid enough. Could be a nice feature for anyone that hates dealing with flush mounting. Some moderate spl distortion tests showed very low distortion to 1khz.
Trying to find a fault, I wonder if thermal compression might be a limiting factor when crossing this tweeter over really low. It doesn't have fluid cooling or the coil surface area of tweeters like the old RS28, Morels, etc. But maybe that thick copper cap will wick enough heat into that heatsink? Just a thought.
Originally posted by Squidspeak View Post
Not to be confrontational but with my limited knowledge I do realize there is a magnet on the transducer, If I am correct it is mounted on the rear of the driver. What I
was asking if there was a measurable difference with or without the screen in place. It would seem that if the magnet was strong enough to hold a metal screen in
place there might be a difference all things considered.
If there's any difference to be discerned it will be from the occluding effects of the screen and not the small change it would make to the motor system.
Originally posted by fdieck View PostA speaker already has the magnet. The screen just has to be steel.
