"Into The Abyss", Tweeters in low places
Originally posted by KEtheredge87 View PostGood lord you weren't kidding! Those faceplates look enormous. That looks like it would rival a 5" driver just for mounting purposes! Is that all due to the chamber behind it? Still kinda hard to get a proper size perspective. Quite interested to read your impressions of them.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
- Likes 2
Hello Xmax. Thank you for posting. If the opportunity presents itself, can you contrast the distortion of the da32 and da25 models? Also, can you post the impedance curve. It is my belief that the slight asymmetry of the da25's impedance curve is related to the transition from the pole vent to the chamber, and am curious whether this is the case with the da32. Good work. P.S. How do these look together?...
- Likes 1
Originally posted by olu78 View PostHello Xmax. Thank you for posting. If the opportunity presents itself, can you contrast the distortion of the da32 and da25 models? Also, can you post the impedance curve. It is my belief that the slight asymmetry of the da25's impedance curve is related to the transition from the pole vent to the chamber, and am curious whether this is the case with the da32. Good work. P.S. How do these look together?...Guess xmax's age.
Preliminary measurements: What you are looking at is the 25 vs 32 (only the 25 is specified) filtered at 1.8K
and 1.4K active LR4 @ my normal mic gain settings and the same output to achieve around 103 dB @ 6" on a 19"X19" counter sunk
test baffle.Guess xmax's age.
- Likes 1
Originally posted by xmax View PostPreliminary measurements: What you are looking at is the 25 vs 32 (only the 25 is specified) filtered at 1.8K
test baffle.
It's breakup of the metal diaphragm, also represented by the 3rd order bump at 8-9kHz. 2nd order distortion of 15kHz is...30kHz, so I think you can determine how important that is.
I think its impressive to see a 32mm metal dome with breakup node above 20kHz, in fact barely lower than the 25mm model. I know several 25mm domes that don't achieve a breakup above 20kHz.I'm not deaf, I'm just not listening!
- Likes 1
Originally posted by dcibel View PostIt's breakup of the metal diaphragm, also represented by the 3rd order bump at 8-9kHz. 2nd order distortion of 15kHz is...30kHz, so I think you can determine how important that is.
I am back on the project tomorrow, the lunatic minister at the church next to my shop dumped gasoline all over a playground
and the property to "kill weeds"!!!!! The fumes were so bad, the misses and I took off to a cabin for a few days...Guess xmax's age.
Originally posted by xmax View PostI am back on the project tomorrow, the lunatic minister at the church next to my shop dumped gasoline all over a playground
Two... I totally conjured up an image of this guy throwing gasoline everywhere yelling "THE POWER OF CHRIST COMPELS YOU!!! THE POWER OF CHRIST COMPELS YOU!!!" for a solid a minute
- Likes 2
