And here is the Peerless TX 32 in Pete's Elliptical WG.
"Into The Abyss", Tweeters in low places
That rs28 and guide looks great guys. Very interesting! I'd like to try one if the file is available and design is finalized.My Build Thread's
Carrera's / Finalist TL's / Speedster TMM's / Speedster MTM Center / Overnight Sensation Surrounds
Originally posted by xmax View Post
Something like "Audyssey" is generally designed for FR correction in the low end as far as I know. That said EQ is EQ whether in the passive XO,
or boosting with a active setup, as long as the results sound good I'm happy.
In wall (or "soffit" mounted for us studio rats.) can do all sorts of good things including eliminate diffraction. Although most housing does not have
walls designed for this sort of thing, with both construction and optimum driver position/angle.
More testing tonight including the TX32 in the same guide.
Originally posted by Mike220 View PostThat rs28 and guide looks great guys. Very interesting! I'd like to try one if the file is available and design is finalized.
I can send you a DXF with all the vectors and you can assign the cut depths yourself if the Aspire file won’t work for you.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
- 1 like
If some small variance in depth is acceptable, and a replacement faceplate can be used, you might consider designing the guide with several faceplates to accommodate different tweeters. This is relatively easy for round guides.
Elliptical guides require a somewhat more complex throat transition surface to reconsile different throat diameters to a given guide contour. The transition surface complexity results because changing the throat depth, as can be done with a round guide to accommodate different tweeter surround diameters, alters the opening from round to oval. Producing the transition faceplates for elliptical guides might be a good application for a 3D printer. This adds another part to the mix, but is worth the trouble to avoid complete separate elliptical guides for each tweeter.
Originally posted by TN Allen View PostIf some small variance in depth is acceptable, and a replacement faceplate can be used, you might consider designing the guide with several faceplates to accommodate different tweeters. This is relatively easy for round guides.
Elliptical guides require a somewhat more complex throat transition surface to reconsile different throat diameters to a given guide contour. The transition surface complexity results because changing the throat depth, as can be done with a round guide to accommodate different tweeter surround diameters, alters the opening from round to oval. Producing the transition faceplates for elliptical guides might be a good application for a 3D printer. This adds another part to the mix, but is worth the trouble to avoid complete separate elliptical guides for each tweeter.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Can a mid/extended range speaker like this be used as a tweeter crossed at 500hz? https://www.parts-express.com/tang-b...river--264-805
Originally posted by Pete Schumacher View Post
This last guide I drew up has a 45 degree vertical opening angle and just under 45 horizontal. It would be pretty simple to scale up the guide so that a .125” adapter plate could be made to match the circular throat and transition to the guide walls very smoothly.
I just sent Xmax a new file of a 1.5” deep 6x9 elliptical guide. It’s set up to match the RST28. I’ve generated the file using Vectric Aspire.
I can send you a DXF with all the vectors and you can assign the cut depths yourself if the Aspire file won’t work for you.My Build Thread's
If you can send me the aspire file that would be swell! Is this for the fabric of aluminum btw? I tried to pm you but it wont let me send anything. Can you pm me your email please?
Pete underscore schumacher at yahoo dot com
won’t be home until tomorrow night.
Seems like a good approach, as I mentioned above though, the transition surface over a short distance, the .125" you suggest, can become somewhat complex, and limited, but it does provide an opportunity to try different tweeters in the same guide, although, the throat configuration does change. I suppose in the interest of science, some additional design, milling or printing, and testing should be done to see how the throat changes affect the guide output. I suspect there is negligable audible difference.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
It seems as though it should work well. You could use a little more or less than 45° to make the transition smoother if necessary. It depends upon how well it is to follow the contour of the guide. Though, I've found with elliptical guides it's best to model it. If a 45° chamfer will work, it makes sense to use it.
A second option is to make the throat opening surface perpendicular to the face plate faces, mount the plate without the tweeter, sand or file it to blend with the guide surface. Then remove the FP, mount the tweeter, mount the tweeter FP combination. Your 45° plate could be faired the same way if necessary. The only drawback is that you wouldn't have the entire geometry delineated with sanding and filing for future reference. But that probably isn't all of that important anyway for prototyping, and I doubt the audible difference between the modeled contour and hand/eye faired would be irrelevant.
