If you have an immediate customer service issue, please email Parts Express at [email protected] or call 800-338-0531, Monday-Friday 8am - 6pm EST.
Just saw this handsome five figure 3 way on Pinterest(Eikon Audio). Nice cab design. Then I thought "That woofer looks familiar. So does that mid.." Sent from my SM-G950F using Tapatalk
They coulda at least squared up the driver holes for that cost...
RS225 for the woofers. I'm betting the 5FE120 for the midrange. Any flavor of AMT could be the culprit there.
"Wolf, you shall now be known as "King of the Zip ties." -Pete00t "Wolf and speakers equivalent to Picasso and 'Blue'" -dantheman "He is a true ambassador for this forum and speaker DIY in general." -Ed Froste "We're all in this together, so keep your stick on the ice!" - Red Green aka Steve Smith
I guess they figured not many people will be looking at the back side of the speakers.....Personally I would be more concerned with eliminating the screw holes in the front of the speakers.
What are you seeing as not "squared up" ? IDK what you mean.
The rear-firing woofer isn't "straight". The screw holes aren't symmetrical, which I agree is a pretty major oversight. Even on my budget designs, the screws holes are lined up as perfectly as possible.
I think they actually are and the angle from which the picture is taken provides the visual distortion.
As has been said that would be far to glaring an error.
I'm certain they are not level across. Even in the set-back angled view, there is no way they would be straight.
If it would be straight, the left screw hole would be on a higher latitude than the right screw hole. As I see it it's either level in the angled view, or just below the right.
I went to their site and found a much better photo of the rear and it's very clear the mounting holes aren't oriented as one would expect, but that doesn't bother me in the least (and maybe that was simply a mistake on the unit used for photos, or there is a reason for it that we're unaware of).
Paul
That did occur to me, but visuals should be better than that. Directional mounts rotation from driver to driver, or highlighting a visual would be a valid reason, but there isn't anything but symmetrics here.
I'm baffled as to why.
