After a few months of reading and researching on speaker building I decided I want to build my own pair of active monitor speakers for my small 3m X 4m X 2.5m room in South America.
I understand that concrete would be a superb material for a sealed box due to the low coloration added to the sound as well as how inert it would make the box allowing for closer placement to the rear wall.
downside being it's weight mostly.
Due to the space available to me I plan on using a woofer size of 5-6 inches to control the bass response.
The drivers I selected for the system are:
-Fountek Neo X 1.0 Ribbon Tweeter Black - 20 watts RMS - 8 ohms - 92 dB 1W/1m4
-Dayton Audio DSA135-8 5" Designer Series Aluminum Cone Woofer - 50 Watts RMS - 8 ohms - 87 dB 2.83V/1m
The MiniDSP kit 2x4 for the active x-o system.
And I'm planning on using a separate mono amp board for each driver so I can place the system inside the boxes.
The TPA3116 D2 rated at 100w, which on a video review of this board was measured to actually output 51.8w @ 4 ohms with a 1Khz sine wave, and 28.1 @ 8 ohms, and a really low distortion
Link to the review of the amp board I watched: https://youtu.be/CULehzRVurc
other options would be the amp boards offered here but most would be overpowered for the tweeter
The questions I have are:
-Is a concrete cabinet a good idea at all.
-Is powering each driver with it's own amp a good idea.
-How would I supply the power for the whole system??, I've been told I would connect everything in parallel with a 24v psu though, and what about the amps needed???
-Would using 4 woofers instead of 2 be better?? so I can get the sensitivity better matched.
Sorry for the long post and would appreciate any help, if my building plans are fine I would be here posting my progress on the concrete speakers.
