Something more on my build. I tested it and i am very disapointed. Not sure what i expected but certanly i wanted it to be better than my previous non calculated speaker. But it isnt. Its not all bad, it still produces decent bass and it is a LOT better than the first few speakers i made which were basicaly tweeters. It still packs a punch and head to head, volume at maximum, it will blow those, i wont mention which, company plastic speakers away. But yeah. The fact that when i cover the port, it makes almost no difference (when in reality it should change F3 from 60 to 100Hz ..) shows that i didnt do something right. It is an acomplishment that i got this bass from enclosure that is probably 2.5 - 3 times smaller than the enclosure of my previous speaker. So that is good. And the material is also dirt cheap. Also good. Also it got me thinking if its possible that the cheap amplifier is simply not sending enough bass into the speakers, i will test that theory with my new amplifier and we will see.
Infact i know i didnt do everything right. I calculated battery volume, battery volume and other things volume and removed them from the equation. But i didnt know i have to remove port volume also, it never crossed my mind, didnt see it mentioned in any video tutorials i saw. Is this the reason i dont get the best results ? I dont know, probably. Right now i am wondering if i can still fix that. Open up theside on which i have port, calculate its volume, put the new enclosure size into equation .. i will probably need to cut the port so it will be shorter due to lower volume.
Also, this PVC really cant handle the bass im putting into it, u can see it rattling madly and only stops when i squize the speaker enclosure. I would be happy of some pointers on what i did wrong and how to correct it.
edit: i need link to where i can buy the pico thing and where i can see their specs.
