To expound - IF both drivers are nearly (perfectly) "in-phase" they'll actually "sum" +6dB from roughly 150-4000Hz.
If the drivers are 90* out-of-phase (same as 90* in phase), as in a Butterworth alignment, they'll sum +3dB over that overlapping range.
With NO filters (and 8ohm drivers), you'll end up w/mostly a 4ohm load.
With simple 1st order filters (cap on FR, and series coil on woofer) the load will be more like 8ohms (if these are 8ohm drivers), and the response will be approx. 90dB (IF you start w/90dB drivers) from about 60Hz up to almost 20kHz (+/- 2dB maybe - depending ...).
