Material to use for small speakers
If there is a cigar store in your area, quite a few folks are using cigar boxes to build small, unique looking speakers. The going price is free to $2.00 each.
Have you tried a product called GOOP? I love that stuff, seems to stick to just about anything.
Originally posted by SentinelAeon View PostHello,
I only just started learning about audio and made my first few small bluetooth speakers. My friends are happy with them and want me to make more.
I have many difficulties and am solving them 1 by 1. One of the problems is finding the right material that is cheap, light and easy to work with.
Most difficulty i have with small speakers of enclosure 2.5L or less. Wood is out of the question because it is to heavy and to thick and therefor speaker will not be as light and compact as wanted. So i ordered some cheap square pvc pipe, you can see it on picture attached. It worked absolutely great for small speakers (the only thing wrong is that its damn hard to glue it with anything, epoxy doesnt work at all). But now it seems i pushed this pvc pipe to the limit. It is very thin. And when i put inside it the mighty Dayton TCP115 (i call them mighty), it makes the pvc pipe vibrate badly at anything lower than 80Hz. And this is a problem.
So i would like to know of some other materials i can use. I have been on the search for very very thin wood, like plywood that would be only 0.5cm. Sadly, i couldnt find it anywhere. Give me some ideas and it would be great if it came in the form of square pipe which would mean a lot less work with cutting and glueing.
I agree that round PVC is more likely to resist vibrating, but if you can find a working adhesive (like Dynamo mentioned above) then I'd bet you can simply glue some simple wooden dowels across the inside of your square PVC to help it avoid resonating. Building braces perfectly spaced/centered means you'll end up with uniform resonating surfaces, so this is a situation where you can happily embrace things being a little crooked and get better results from it.
Using some sandpaper to roughen up the PVC surfaces you're trying to glue may also help give the adhesive something more to grip onto.
Personally, I've had great luck so far using 1/4inch (about 0.6cm) plywood which is very cheap and lightweight for smaller boxes (around 2-7L) though the bracing from side-to-side is still going to be somewhat important.
I agree pvc is pretty resistant to normal glues like epoxy and CA. I’d recommend using the specific pvc primer and adhesive from the plumbing department.
I think your problem is that light and compact aren't going to make a very good cabinet for the TCP115. Light and compact work for tiny little speakers without much low frequency output. Maybe aluminum? May be hard to "build" a cabinet but to Tom's point, you might be able to find clever aluminum/metal boxes to re-purpose. I know over at diyaudio.com someone just build an amp in an old computer case.
You can use 1/4 inch birch plywood. It is very light but, I would put bracing inside the enclosure if you have enough room.
- Likes 1
https://www.homedepot.com/p/Underlay...-202093874-_-N
Some folks seem to be good at finding existing prefabricated and prefinished boxes for other uses from places like Target, or Ikea, places like that... they use the box as a pre-fab enclosure and just make a baffle with speaker cut-outs to mount the drivers.
Do a little digging and you may find something that would work.
Hello,
So i would like to know of some other materials i can use. I have been on the search for very very thin wood, like plywood that would be only 0.5cm. Sadly, i couldnt find it anywhere. Give me some ideas and it would be great if it came in the form of square pipe which would mean a lot less work with cutting and glueing.Tags: None
