Originally posted by guitar maestro
View Post
vacuum tube amp recommendation ≤ $600
Originally posted by fpitas View Post
I guess you know. Good damping factor and lots of power are cost drivers for tube amps.
Originally posted by guitar maestro View Post
I suppose it's one of the things that I would have to sacrifice if I'm staying near-around the $1k mark. All would not be lost though. If what ever I end up buying doesn't live up to my expectations, I will use it in my office at work with the Studio HD's. RIght now I have them at home since I'm on vacation, but come August they go back to my office.Francis
Honestly I'll be shocked if tubes sound any better when used below say, 200Hz. Maybe above there you'll get benefits over the cheaper solid state amps.
Thanks for your input. Based on the info I've given, if you had to twist my arm to buy one of those amps I listed, which one would it be and why?Francis
Honestly, no idea. I'm a solid state guy for the most part. I can design tube amps, but other than that what I know about commercial amps is from observing the tube threads at DIY Audio. You may get some good info there, several very good designers hang out.
This question was asked of me when trying to decide what it was I wanted from the 4sUniversal diy tube preamp, which is an easy to build preamp designed for 'tube' sound and the ability to row about a dozen tubes, not accuracy or low distortion.
Do you want that 'tube' sound (mainly 2nd order harmonic distortion) or accurate and low distortion sound?
Both 'flavors' can be had with tubes. IMO, a tube pre/amp designed for clean and accurate reproduction is going to be hard to tell apart from its ss counterpart, comparing apples to apples of course, while a tube pre/amp designed for oodles of chocolate tube sound is distinguishable from a ss or tube pre/amp designed for clean, accurate reproduction.
With that said, I'd agree with Carbon, try a tube pre that is designed for dark chocolate not low distortion and accuracy. Oh, parts quality and layout can make a huge difference in tube gear.
YMMV
What speakers are you using? Sensitivity will be a factor if going with tubes, especially given your musical tastes. I would think that a good solid state with a higher dampening factor may be better for metal (think bass dynamics) versus tubes. Don't get me wrong, I love my tube amp but I also have solid state gear that I use depending on speakers and application. Of the choices you listed, the Reisong intrigues me the most given the positive reviews but I've also heard good things about the Yaqin products. No first hand knowledge with either. What's your source?Carbon13
Originally posted by Kornbread View PostThis question was asked of me when trying to decide what it was I wanted from the 4sUniversal diy tube preamp, which is an easy to build preamp designed for 'tube' sound and the ability to row about a dozen tubes, not accuracy or low distortion.
YMMV
Originally posted by Carbon13 View PostWhat speakers are you using? Sensitivity will be a factor if going with tubes, especially given your musical tastes. I would think that a good solid state with a higher dampening factor may be better for metal (think bass dynamics) versus tubes. Don't get me wrong, I love my tube amp but I also have solid state gear that I use depending on speakers and application. Of the choices you listed, the Reisong intrigues me the most given the positive reviews but I've also heard good things about the Yaqin products. No first hand knowledge with either. What's your source?
OK - those Legacy Audios are fantastic speakers, but really not what I would personally recommend for tube amp usage. At least their efficiency is relatively high, but the 4-ohm load will make it very tough on tube amps unless the output transformers were specifically designed to handle that.
You'll need to add 4-ohm compatibility to your list of requirements.
Also, to one of your earlier comments, "Metallica and Antrhax" do not necessarily constitute difficult to reproduce music, and generally are not what I would call difficult on an amplifier. Believe it or not, the dynamic transitions in classical music are actually much more "difficult" for an amplifier to reproduce accurately than more popular compressed music genres. That's not to say that some Metallica or metal music isn't difficult. The kick-drums in "And Justice For All" can be particularly harsh.
Originally posted by tyger23 View PostOK - those Legacy Audios are fantastic speakers, but really not what I would personally recommend for tube amp usage. At least their efficiency is relatively high, but the 4-ohm load will make it very tough on tube amps unless the output transformers were specifically designed to handle that.
You'll need to add 4-ohm compatibility to your list of requirements.Originally posted by guitar maestro View PostI'm looking for suggestions to purchase a 2-ch vacuum tube amp for an auxiliary 2-ch system, not my main system. I fully realize that I will likely have to purchase from overseas, which is fine, so long as I'm getting a good value.
Requirements:[LIST][*]4 ohm capable
Originally posted by tyger23 View PostAlso, to one of your earlier comments, "Metallica and Antrhax" do not necessarily constitute difficult to reproduce music, and generally are not what I would call difficult on an amplifier. Believe it or not, the dynamic transitions in classical music are actually much more "difficult" for an amplifier to reproduce accurately than more popular compressed music genres. That's not to say that some Metallica or metal music isn't difficult. The kick-drums in "And Justice For All" can be particularly harsh.
Do it right. It just LOOKS like a ST-70. They sell tube preamps too if you just want a tube sound. Old school with tape loop and phono input. Otherwise the power amps have an optional volume knob if that's the only preamp function you desire.
Edit: You can compare this company's preamps to those Behringers, but I wouldn't.
http://tubes4hifi.com/bob.htmLast edited by djg; 06-12-2020, 03:02 PM.
