Originally posted by SentinelAeon
View Post
If the DC130 is used as a midwoofer where its lows start getting cut off around 200hz or higher and sent to a subwoofer, then the DC130 can get really loud, but when it's used to play lows below 200hz its limited XMAX/movement can limit how loud it'll play without going all "flubby". I think that limit will be around 97db or lower....and another 3-6db lower from bafflestep losses.
Did you mention one or more of these amps being 2ohm stable earlier?
If that's still an option, a pair of TCP115-4 in parallel at 2ohms should be easier to drive to full power and still have more headroom.
