Hello everyone. I am from India and i entered this mystical world of beauty of sound a few years ago. I am planning to build a 2-way speaker using Markaudio Alpair 7 ms ms and Peerless 830869 woofer.
The 8 inch woofer to be housed in a MLTL enclosure, preferablyepreferably straight,to be of 30-40 inch height. My goal is to reach F3 between 35-40 Hz, frequency response should be flat as far as possible and clean low end. The depth of the enclosure will be preferred not to be more than 12-13 inch.
The Markaudio driver will be housed in a sono-tube like enclosure made of PVC or Metal pipe which can be lined with foam to prevent internal reflection.
I am planning to bi-amp the speaker using passive line level crossover.
I need help to plan the enclosure dimensions, driver placement, port dimensions and location. There are many experienced and knowledgeable builders here and I sincerely request everyone here to help me to make my first build successful. Thanks in advance.
Links for the drivers:
Woofer - https://www.parts-express.com/peerle...ofer--264-1098
Mid- tweeter - https://www.madisoundspeakerstore.co...-5-full-range/
