One of the great things about this forum is the experience and expertiese of its members. A couple of years ago I started a post asking about the "Real world importance of cabinet bracing" in a 1CF box and learned a lot about the topic. However, the discussion got pretty esoteric and my final decision after studying 6 pages of posts was to line the cabinet with ceramic tile and use the following bracing scheme. " I plan to glue in a side to side and front to back brace centered on the tiles. These braces will be 3/4 X 1 1/4 plywood. Each brace will consist of two pieces, overlapped 4" and glued with a 1/8" thick layer of silicone glue as shown in post #56 to load the flexible glue in shear."
While there was one comment that this seemed like a good plan, there were 3 of comments which suggested that it would be better to use a thin layer of construction adhesive instead of a 1/8" layer of silicone because the silicone would be too flexible. Of perhaps greater inerest to me, were comments that there would be little or no audible difference between this approach and no bracing at all (!) and comments that even simple fore and aft braces might result in the speaker sounding worse. There was consensus that an inert cabinet is always desireable, but much disagreement on theoretical grounds about how to get an inert cabinet.
So (without going into too much abstraction) what is your real world experience as to what you would do in order to build a 1/2 to 1CF cabinet that colors the sound minimaly? I know that the tile lined Keremiskas are outstanding, and that Rasmus' (if I remembe his name correctly) super heavy lead lined speakers won the InDIYana theme contest and that Ben has used a super stiff, mass loaded cabinet to good effect. I THINK that bracing of some kind probably results in some audible improvement, but have never compared or measured any speaker I have built with vs.without bracing. I THINK that a doubly thick baffle (1.5 ") might result in reduced cabinet coloration but have never A-B tested or listened to a speaker with a single thickness vs. double thickness baffle.
Many of we DIYrs like to experiment, and I'm betting that some of you have personal, real world experience in what matters and what doesn't in terms of building an excellent, if not state of the art, 1/2 to 1 CF cabinet. Your knowledge and personal experiences are hearby requested.
Best,
Jay
Best,
Jay
