You may be surprised at those Apex tweeters.
Brainstorming a driver config for a *very* cheap 10" 3-way retrofit
After a few more coats of bondo and glazing putty the cabinets were ready for the new vinyl wrap. This was some cheap stuff that I picked up on Amazon for $8/roll. It's Waaaaaay thinner than the wood grain vinyl that I used from PE in the past. Overall it's going ok, but I have some serious concerns about how durable this stuff will be. Hopefully tomorrow I'll get it wrapped around to the front side.
That looks fairly complicated with the angles at the front. It came out remarkably good looking, though.
You must have taken your time and not had too much coffee?I can see me getting a little frustrated with it if I were doing that. I've done vinyl a few times and didn't feel I had the knack for it.
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
This vinyl sucks. Some of my edges aren't staying down and some of the vinyl around the front chamfers is lifting. One speaker already had the vinyl on the bottom tear from sliding a few inches on the floor. I miss the stuff that PE used to sell.
Anyway, today I got the tweeter holes enlarged, I plugged the screw holes for the midrange and drilled the new ones, I installed foam in the midrange cavity and I got the drivers installed into one cabinet. Now I need to get my Soundeasy test jig built so I can start my measurements.
For the tweeter cutout, I used a 3" hole saw along with an MDF guide.
worked perfect.
they still aren't much to look at.
As ugly as they are, they're looking better than they started.
- 2 likes
This afternoon I had time to finally go through the soundeasy documentation and bulldoze my way through some measurements. I'm running v17, but my manual is for v12, and I'm not sure what version John K used for his tutorial, but it's quite different from my version too. It's been a challenge, but I'm getting measurements. I measured one of my original speakers (that beauty of a frequency response is on the laptop screen) as well as all of the new drivers in the other cabinet. I'll retake them after I get it more dialed in, then start figuring out how to get my phase data reliable.
But check out that stock frequency response.
yeah. I raised the speaker up after this picture and was able to watch the broad hump around 1k disappear from my measurements, but I'm still too close to the back wall. I need to partially re-arrange the room to get good measurements, so for now I'm just doing it this way to get my head wrapped around the software.
