so last night I remembered that I had a pile of the old Vifa/JBL buyout 4.5" speakers that PE had somewhere around 2004 or 2005. I've got 2 flavors, 299-432 that have foam surrounds, and 299-495 that have rubber surrounds. I used 1 pair of the 495s in a small 2 way that I've been using since. I never used the 432s. I've still got the FRD & ZMA files for them, so they may be worth fooling around with. They fit beautifully into the midrange openings of these cabinets, so they might be a possibility, though I remember those 432s having a notched response that would be perfect in a narrow cabinet to compensate for baffle step losses, but would end up being problematic in these big cabinets, so the 495s might be a better option.
Brainstorming a driver config for a *very* cheap 10" 3-way retrofit
I'm not really sure that fits my design goal. I still want to keep this in that "party speaker" kind of realm, and to me, that's a traditional 3 way design with a nice fletcher-munson curve built in. I'll probably end up using an open backed midrange/midbass driver that will require a dedicated sub enclosure, but I want to utilize a dedicated tweeter, since there's already a hole in the cabinets for one. My hope is that I can use the woofer-mid crossover area as a quick & easy way to integrate the baffle step compensation too.
How about a F.A.S.T. design ("full range and subwoofer technology," or "full-range assisted by woofer" - not my acronym)?
You could use the DA-250-8 and your choice of full-range in a small sub-enclosure. Some candidates: Visaton frs-5x, Tectonic TEBM46C20N-4B BMR, Tymphany TC9-FD18-08 (TC9 may be too low-efficency, depending on how much baffle step compensation you need for where the speakers will be located). If you want to go the lazy way for the sub-enclosure, surface mount the full range driver above the woofer and glue a chinese take-out soup container filled with damping material to the back of the front baffle behind the full-range. Use lots of glue and prep the surface first, a leak would be bad. If you are concerned with the woofer flexing the soup container, nest a couple of them so it is double-walled. Leave the unused old drivers in place,disconnected, to fill their holes. Not state-of-the-art, but won't be bad and will be cheap.
Just realized when you said you're aiming for "driver costs under $100 total" you meant per PAIR rather than per box (after noticing the mention that a ~$30woofer and ~$6mid only leaves around $12 for tweeters). Was originally wondering why things sounded so tight budget-wise while thinking "I don't get it, $20/20/60 for a threeway seems like plenty of room". Makes a lot more sense after pulling my head out, lol.
With that in mind, and the difficulty of reselling, maybe the GRS being a little cheaper might be worth it afterall (assuming 4ohms isn't going to shoot some feet).
Has anyone here tried them to see if their claimed XMAX is anything near reality or if it's a distorted mess?
If you're thinking about a cheap-ish GRS but want to avoid the accordian look (and their usual low XMAX limits) I think the rubber-surrounded GRS SW10-4 models okay in that box (guessing around 45L...didn't see it mentioned) F3 around 40hz ported or 50hz sealed. BUT I think the DC250 models really similarly for the low-end, and the DC probaby has more accurate T/S params compared to what's given for GRS while only costing about $7 more...similar or higher sensitivity with the DC while keeping 8ohm stable too.
EDIT: duh, that's the "poly GRS woofer" you were already talking about. Might be worth a look if you prefer 4ohm and sealed (assuming its XMAX advantage is real), otherwise I'm guessing the DC would still be better.
- 1 like
Your choices of the DC250 , buyout mid, and BC25 seem solid. The DA270 is nice too but destroys the budget.
Whats the Realistic speaker on the left?
- 1 like
I'll be devil's advocate and point out that you can end up spending more overall using very cheap drivers, because the crossover gets more complicated.
- 1 like
Originally posted by cooper View PostI would look at the GRS paper woofer. And, a white van to sell them out of
GRS does have the one poly woofer though. I should see how it models in the enclosure. It's a much higher q than the Dayton, but that might give me a nice bump at 45 or 50hz.
- 1 like
so over the weekend, I may have succumbed to an impulse buy, and came home with 2 dozen speakers. Well, technically 25.
Most of these are cheap MTX AAL 10" "3 way" speakers that are, well, terrible. Most of them I'm going to resell, but I've got a few with bad woofers. My son took an interest to this whole fiasco and we discussed replacing the woofers, but since these sound so bad, I started thinking out loud and we ended up discussing a total upgrade. I don't really have the ambition to do a scratch build, especially considering what MDF costs now, so I want to reuse the cabinets, and would like to make my life even more difficult by trying to avoid enlarging any of the driver cutouts, but I'm flexible on that.
This is what I'm starting with:
Drivers consist of a 10" woofer with a 9.25" cutout, a 5" sealed back midrange with a 4.125" opening, and a horn tweeter with an opening of 2.75".
On a side note, the "crossover" on these is a joke. The woofers play full range, the mids have a single inline cap, as do the tweeters. The output on the mids is so low that you could disconnect them entirely and probably not notice.
My design goals are to have a speaker with a considerably improved sound quality (this won't be difficult - the bar is set very, very low), driver costs under $100 total, and a more pleasing aesthetic. I'm really after a Cerwin Vega party speaker type of sound that sounds good loud and isn't fatiguing. I'm not going to be playing Brahms on these, I'll be playing Metallica.
I'm having a bit of difficulty in selecting drivers. For the woofer I think I've settled on the Dayton Classic 10" (DC250-8). It models reasonably well in this enclosure with an F3 of 38hz and only a very mild bump in output around 50hz, which honestly, is fine with me for this type of speaker.
For the midrange, I'm a bit conflicted. The idea of some of these sealed back mids appeals to me because they're a simple drop-in replacement for the existing hole, but this will either require a notch to get rid of the high Q spike on the low end, or a higher crossover frequency than I'd like. Either way, these won't extend low enough for me to cross the woofer to the mid at the baffle step transition, which would have been ideal. Another option is to suck it up and build a sub enclosure behind the midrange, which opens up the option of using something that can cross down near the 300 baffle step transition range. It also lets me use the 4" paper woofer buyout that PE has for $5.80. Even though this driver is 16 ohm, it looks like the sensitivity is high enough to work with the Dayton Classic woofer. If I build a 5" cube behind the mid opening, I model about a 3dB bump at around 250hz before it rolls off sharply. This should lend itself well to a somewhat simple high pass filter for the mid.
So, if I go with the Dayton woofer and the $6 mid, that leaves me just under $12/each for tweeters, which obviously isn't much. I could go with some variety of the Peerless BC25s, or maybe try out the Apex Jr tweeters that sell for $15/pair. Those have a pretty hot top end, which I think would be a nice book end for the bump that the woofer has at the low end.
For aesthetics, I don't really plan on doing much, but these enclosures are pretty beat and most of them have a bunch of screw holes from various mounting brackets that were installed from their years in bar rooms and other public places. I'm figuring on filling the screw holes and either painting them black or maybe laying a new fresh layer of vinyl wrap.
At this point I'd love to get some general feedback from the collective about the plan. I realize 100% that these aren't going to win any awards for sound quality, but my goal is just to have a fun project with my son, and re-acquaint myself with the overall process of using Soundeasy, designing and implementing some filters before I get back into trying to use up some of the higher quality drivers that I've been sitting on for over a decade.
Tags: None
