Two-Way Version 2 build thread
  • DeZZar
    Tackling the main box now. Again marked up the leather wrap to try and keep the glue-up tidy. Working with contact adhesive can pretty quickly get out of control and you need to take care you don't get drips and strings of the stuff all over the place.
    Not easy but I find brushing it on and working with small "fresher" amounts in a separate cup is the way to go. If you pour a lot out into your "working" cup it can end up getting thicker and tackier as you try and work with it. Fresh adhesive from the can is thinner and spreads really easily. Just don't brush it back and forth a lot - apply, spread, leave.
    Anyway so here lining it up. I glue this on in sections obviously. Just have to make sure the glue goes on smooth without pooling it up anywhere or allowing any joining areas (where you stop and then resume) to end up with a build up of glue - this will show through.
    Starting with the bottom edge and then flipping it over for the back and finishing back up in this position for the front.
    Flipped over, now for the back.
ID:	1470861 Click image for larger version
    Pausing here to trim and fold into the edges of the rear crossover compartment.
  • Steve Lee
    Fabulous!
    Thanks for sharing this technique.
  • DeZZar
    Now they can be flipped back over and glue applied to the recessed area.
    Click image for larger version  Name:	IMG20210605142215.jpg Views:	91 Size:	703.2 KB ID:	1470781
    Stretching and smoothing the leather in place. Here you can see how the recess makes that a lot easier.
    Click image for larger version  Name:	IMG20210605143410.jpg Views:	92 Size:	593.6 KB ID:	1470779
    Then a final trim. Again made really easy with the recess as you can just run the knife down the groove.
    Click image for larger version  Name:	IMG20210605133645.jpg Views:	91 Size:	452.5 KB ID:	1470778 Click image for larger version  Name:	IMG20210605133639.jpg Views:	93 Size:	650.8 KB ID:	1470777
    Ta-da two sides panels ready to go. Now onto the cabinet body!
    Click image for larger version  Name:	IMG20210605144331.jpg Views:	91 Size:	563.7 KB ID:	1470780
  • DeZZar
    Excess trimmed from the center.
    After making some relief cuts in the corners the edges can be folded in and then given a final trim.
ID:	1470774 Click image for larger version
  • DeZZar
    Marking out the position and where to lay glue down for the sides. The panel is centered on the leather piece and then the sides folded up to mark the wrapped width. This leaves you with an outline of where to place glue and a refence to lay the panel back down once the glue is applied.
ID:	1470769 Click image for larger version
    Applying contact adhesive to both the panel and the leather.
    Panel then gets laid down on top again the edges drawn up around the sides.
    Flip it over, press and smooth the leather in place and then trim the excess from the center.
  • DeZZar
    Now that all the round overs are done its time to remove the sides and start cutting the recesses in the back edges for the leather wrap.
    In the meantime I also marked and pre-drilled holes for the screws. The sides will be glued down but the screws will act as clamps and make sure there is a tight seal during the final glue up.
    Because of the curved profile I wanted to carry that theme into the shape of the timber panels that will go on the sides. But cutting a small curve here would be a rather painful task so I decided instead to print these small plastic profiles and glue them in. This way is a consistent shape and no mucking around with fiddley little bits of wood.
    On the back edge of the side panels and the joining surface on the box a small 0.7mm deep rabbit is cut on the router table first, and then a dovetail router bit adds the additional gutter for the leather wrap.
    The gutter is especially for the corner profile and gives somewhere for the 'bunched up' leather to live without getting in the way.
  • DeZZar
    Originally posted by mattk View Post
    Definitely cool. Technically a dried layer of cellulose lacquer could be considered clear wood.
  • mattk
    Originally posted by DeZZar View Post
    Hahaha! Maybe one day if I'm really bored and feeling the need for some cheesy bluetooth party speaker that glows in time to the music or something!
    Transparent wood:
    https://theconversation.com/transpar...o-glass-154981
  • DeZZar
    Cutouts and recess made for the rear panels. This is designed to hold the crossover and speaker terminals.
    Plan is to have a removable gloss black painted panel screwed in here for a bit of contrast to the leather.
  • Steve Lee
    Very competent work.
  • DeZZar
    Side panels fixed temporarily in place so they can be rounded over with the entire box.
    Top and bottom edges received a 36mm (1.4inch) round over and the sides 25mm (1inch).
    After much sanding and smoothing both boxes nearly done. A couple of little minor areas to fix up just to make sure nothing shows through the leather wrap.
  • jhollander
    Not sure it would be cheesy if you do the same level of craftsmanship, it's quite impressive and would be cool to show off.
  • DeZZar
    I was hopping for clear sides
  • jhollander
  • DeZZar
    Both baffles fitted, and the port transitions smoothed over. Now time for the sides...
    Temporarily fixed the port in place to start testing FB
    Temporarily attached the sides and fitted the woofer. Few iterations of FB testing later the port has gotten 75mm shorter than modelled! Might leave it there....
