If you have an immediate customer service issue, please email Parts Express at [email protected] or call 800-338-0531, Monday-Friday 8am - 5pm EST.
Do you mean, why the ported has more xmax below the port tuning? The cone is basically unloaded there. The port has become a big hole in the box, and you won't get much sound down there, either.
Look at the charts again. The ported has higher output below 100Hz. At 35Hz the ported sub is 8dB louder with half the excursion. The ported sub only has higher excursion below 30Hz, where it still has a decided output advantage.
Yes i understand and i don't want to use the sub for 20hz but just curious because they have the same spl at 20hz but ported have a lot more xmax. I understand a ported design have more spl but this is the other way around. Cone excursion = cone excursion, so why less spl at 20hz. Just for the facts !
You've been told already. The port is a hole in the box down there.
At low frequencies below resonance the air from the rear of the cone is pushing air out the port in the opposite direction to the air being moved by the front of the cone. The two sources of sound are largely cancelling hence the large cone displacement creating little sound.
Ok this makes sense i gues. So its the opposit effect as at tuning frequency ? I just wanted to know this because i tought maybe the app have some errors in it.
