This project has been in planning for years.... Here's my living room HT setup.
That's an IKEA Besta cabinet for the equipment, modified slightly to not overheat stuff by leaving the back open with a cross beam for stability, and using a hole cutter under the AR on the left and the PC on the right to allow air in from the bottom. Nice little setup for what I've got.
That sub cabinet on the right is an Eminence Lab 12 driven with a 200W plate amp, the box is about 30 years old. It's survived my teenage years, moved around with me in college and beyond, and has landed here. It's been peed on by many pets, soaked up spilled drinks, been re-built a few times, sanded, refinished, and that grill has been busted off and repaired countless times.
It's also not super optimal. It's big, ~4 cu ft, but constructed from 5/8" particle board with a 3/4" baffle and no cross bracing, just a couple 1x1's glued at an angle to add some rigidity to the sides. The port is a little small at 3.5", but surprisingly chuffing is a rare problem. It also works really well for my use, response into low 20's and loud enough to feel the floorboards shake for movie effects, also accompanied by shaking whatever we have on top of it to the floor. It's just showing some major aging, like this:
That's many, many years of moisture damage.
So after trying to come up with cabinets to match the rest of the aesthetics, I thought... I have another Besta frame and feet sitting in the garage with a glass top panel and everything. Why not use that and build it into a sub to perfectly match the entertainment center?
The Besta frame is not what I would call robust enough for a decent sub. The sides are 3/4" particle board, and the top and bottom are about 1 1/8" thick but hollow, made from what seems to be 1/8" HDF with a cardboard lattice between them for rigidity. The idea is to use 1/2" MDF cut and glued around the frame for the cabinet walls, with a 3/4" MDF rear panel and a doubled 3/4" MDF baffle. The port will be a 4" precision port firing down to the floor. Looking like this:
Calculating that up comes up with 3.63 cu ft of volume without driver, bracing, or port. Modeling the Lab 12 in that sucker works fine, ~3.25 cubes net tuned to 21Hz with an F3 around 25Hz. I cab pull this off with a couple project panels from the hardware store.
For aesthetics I'm going for roll on Duratex on the back, and wet sanded gloss black on the front to match up with the glass doors a bit on the entertainment center. For the woofer, I really liked how the recessed metal grill ended up looking on my little Indy 8 sub, so I want to do that here. I found a JL Audio SGRU-13 grill for their 13" woofers that will give plenty of clearance around the Lab 12 frame and room for full exertion. The outer baffle board will be cut to fit that grill in place, press fit with some weather stripping to keep it in place and kill rattles.
The trickiest construction bit will be getting the precision port through the bottom. My thought is to seal the inner board right against the 4" tube. The cut out of the IKEA bottom panel will be ugly, so the flare will be needed to hide that, and I'm hoping the flare is done by the time the 1/2" MDF board is reached. We'll see how that works out, some improvising may be in order.
Ordering parts today.. I should be able to pull this off for around $100!
