Keen to see how this turns out. What infill are you going for?
3rutu5 epic failure series - july edition
Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
Refurbs: KLH 2 | Rega Ela Mk1
i had 3mm thick inner and outer walls, with 80% infill. I was going to do 100% but forgot. Last design i did i went with solid walls and it was really sturdy.
Had another issue before, didnt stick to the bed and i went down to a nice chunk of PLA stuck to the nozzle. All fixed and not too far into the print job.
I think it'll be plenty strong with 80%! Hows the print looking - any print progress pics?Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
appolgies to all, i have poor lighting in my garage
apparently it is 50% through the total built which is a bit light on the estimate of 2 days 5 hours, but im not going to complain
im not concerned about the stringing either, its like a mild spiders web and will disappear when i remove the two pieces from the bed.
The walls will basically print solid due to being 5mm as a minimum, and from the phantom build 5mm and thick is pretty good and sturdy, albeit going from a 2.5 inch full ranger to a 5 inch will be interesting, but at the end of the day the side walls will end up being 10-20mm thick with the timber/PLA sides.
Which 3d printer is this?Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
I'm currently thinking of the best way to power these, would i be correct in assuming a 2x15w Dayton DTA2 class T amp module being not enough juice for a hifi woofer and full range? It was great for powering a pair of TEBM65's and loud, but not sure about pushing the friendship on that one.
Originally posted by DeZZar View PostWhich 3d printer is this?
Looks fantastic mate. Will the sides be 3D printed as well?Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
Originally posted by DeZZar View PostLooks fantastic mate. Will the sides be 3D printed as well?
I was thinking that the black PLA (once prepped and painted) would contrast the wood quite nicely fitting in with the curved timber design and black TV im sitting at.
Im not sure i can achieve the original mount for the driver as it would appear i've overlooked the overall diameter of the 5inch and you can notice it cuts into the groove. Yes i could bolt it directly to the side and make it look nice, but i would have to drop the timber side. I could rear mount the woofer as well but means i would either have to expoy the side on making any modifications difficult in the future or work out a way to get some bolts into the current print either by 3d printing and glueing some hold points or some other means. lucky this 3d printing caper takes some time.
