I imagine I will make the Duane Brown design Dayton 4. Then it would be timber matching and aesthetically matching to my center channel.
Of course DeZZar would want me to skip all that and buy something already made like the Dayton MK402X but that’s no fun.
Can you make a C Note box any smaller?
Another small design. I've built all these save the Duane brown design.
https://techtalk.parts-express.com/f...fa-hibm65c20-8
The satellites in this 2.1 design are quite nice, quite small.
https://techtalk.parts-express.com/f...room-or-office
Flat pack kits Passive Aggressive, Overnight Sensations and Tri Trix TM all in stock and feasible I think.
Cheap 4" Dayton 2 way design 8.5" deep. Woofer back ordered for a month. Well received.
https://duanebrowndesigns.blogspot.c...-speakers.html
Originally posted by djg View PostHave you already bought these things? There are oodles of designs smaller than the C notes. You obviously can build a box, I don't think you're limited to flat pack designs.
The maximally flat alignment is .22 cu ft vented with 54Hz Fb. There was a previous version of this driver with different specs that worked best in a much larger box, which could be part of the confusion. However, you also have to account for the volume inside the box taken up by both the driver and port. It would be worthwhile learning how to use WinISD, then you could figure these things out yourself.
Originally posted by Jicafold View Post
I seriously do not know what the recommended distance of a rear firing port from a posterior wall is. I was guessing.
Originally posted by Chris Roemer View PostIs there a reason why you wish they were 2" shallower?
All other things being equal (which they seldom are), if you decreased the box volume by about -25%, I'd probably recommend making the port roughly +1" longer (if you can). Even with that change, you'll probably lose about 5Hz off the bottom end.
Don't put so much weight on the "recommended" volumes listed on the product pages. Those are relatively arbitrary and really only useful as a starting point for when you put the woofer into a proper modeling program (BassBox, WinISD, whatever). There are always trade offs.
You could do that if you like, but you'll need to redo the port as well to properly align the woofer and the bass extension will be different from the design as planned. I'm not sure how much low extension you'll lose without modeling it, but it will be some. However, as long as you keep the baffle the same the crossover should stand as is.
Can you make a C Note box any smaller? The dimensions of the supplied box in the kit are 11" H x 7.5" W x 9.5" D. This is with the ½ inch MDF. Volume box calculators indicate that this is an internal volume of 0.32 ft.³. The Parts Express webpage for the Dayton Audio DSA135-8 5" Designer Series Aluminum Cone Woofer indicate that it requires a 0.2 cubic foot volume for a vented box. I read the only reason this box was made that big was so they could also include the amplifier for a powered version without changing it. So… Can I make this box only 7.5 inches deep? That is still and internal volume of 0.24 ft.³. Considering space for drivers and crossovers, etc., it would still be at the recommended 0.2 feet or more.
Tags: None
