Guys this is a random one, as some may know I bought a heap of cheap bt amp boards due to their size and apparent ability to modify the onboard.chip. I recently got myself the USB Csr programmer and little pogo pin harness so I can edit which will be interesting.
I have a couple of those 2 inch peerless FR drivers and going to have one in that booze tooth build, but I think the box might need to be 0.01cuft bigger or two. So could somebody tweak the onboard EQ to lift that lower end? Keeping in mind this is a 5v system and most likely have 3w output, so nothing to shake walls etc.
Another question was somebody mentioned stripping a LAN cable to use for these small boards due to being thin, could someone use this thin cables for the power leads? As in to the battery?
Bonus round question.....I know there are a few torch enthusiasts in here, so any recommendations in brands for a 16340 / RCR123 battery?
