Probably just annoying members more than being helpful, but I'm sure I'll be flammed If I hit a nerve... For the last 12-18 months I've been attempting to make something that's portable, small and a bit of fun. I've had a go at the quaranteenie and 7 iterations of the beer cans. Most of the beer cans honestly haven't been successful as to cram everything in you sacrifice the internal volume in some way or another. This has been the first almost completed version where a port was used in lieu of passive membranes.
I'm still trying to work out the EQ settings to help compensate the slightly smaller box. The Chinese by/amp board has a Qualcomm module which is fully customizable via a USB-spi programmer. I've also sourced a 18350 li ion battery with a 1200mah capacity and designed the top to be able to be unscrewed and have complete access to the battery, buttons/switches, buck converter and the amp.
The driver used is a 2 inch peerless one from a Google home device and as it is powered by a amp that runs of 6.5v will be lucky if it will put out 5 watts per channel. The port is 10mm diameter and about 120mm long.
