I am a newbie here would like to say Hello! to all.
Just received this pair of 7 inch woofers which is DA's latest woofer. It looks awesome and I was planning to build a pair of stand mounted speakers for my living room (2-way). I was hoping to get the Fountek NeoX1.0 tweeter which has a recommended crossover at 2500Hz, 2nd order. I used the crossover calculator at https://www.diyaudioandvideo.com/Cal...akerCrossover/ which recommended around 4uf capacitors x 2 and inductors at 1mH wired in a 2nd order LR fashion.
So far could I ask if the above is good enough ?
The next stage is to design the enclosure. I quite liked the L-SLOT VENT BASS reflex enclosure and came across this design tool http://dbdynamixaudio.com/l-slot-ven...re-calculator/
Are there any suggestions at this stage?
I was also wondering about the volume taken up by the woofer and the tweeter - how does one calculate that and factor that in the speaker design
Thanks very much in advance for your thoughts and suggestions.
Abraham
Abraham
