EPIQUE-E180HE-44 - New build help
  • #16
    Wonder how the Dayton RST-28A would work with the Epique-E180HE-44??? Kinda sorta made for each other. Now the RS-28A should be a natural...if you got 'em.
    • #17
      Hi Chris,
      just wondering if the position of the L-pad SR and PR make any difference if they were first in the circuit such as in the pic below. Many thanks
Name:	Screenshot 2021-09-03 at 23.08.21.png
      • #18
        DO NOT place the Lpad (SR + PR) before the xover circuit. This places a load directly across the amplifier for the full bandwidth, and the resistors will get HOT, likely to cause a fire.
        The xover is optimized for the load after it. While it is okay to place a series resistor prior the xover circuit, the parallel resistor MUST ALWAYS be placed after the xover to prevent the issue I stated above..
        • #19
          Great thanks very much
          • #20
            Another aspect the front baffle -
            1. Is 18mm mdf thickness ok or not enough ?
            2. Placements of drivers and port - sort of done a sketch with different types. Any particular design that would work better ?
            A1,A2,A3
Name:	Baffle design 1.png
            B1,B2,B3
Name:	Baffle design 2.png
            • #21
              1. Someone will probably say it's enough...but I would personally go minimum of 24mm. I go 36mm when I can but you will need to chamfer the rear inside edge of the woofer cutout.
              2. A3. A1 is fine but just a little aesthetically strange. You can do something like A2 if the port is between say midrange and woofer in a 3 way. But in a two way due to high crossover point you want to keep these drivers as close together as practical.
              • #22
                Originally posted by DeZZar View Post
                1. Someone will probably say it's enough...but I would personally go minium of 24mm. I go 36mm when I can but you will need to changer the rear inside edge of the woofer cutout.
                Great thanks. What do you mean by "changer" the inside edge of the cutout.
                • a4eaudio
                  a4eaudio commented
                  Editing a comment
                  Should have been "chamfer"
                • DeZZar
                  DeZZar commented
                  Editing a comment
                  Yeah, sorry that should have been chamfer. Wolf's example below is pretty fancy. I use a 45 degree flush trim router bit.
                • Wolf
                  Wolf commented
                  Editing a comment
                  Yep- 45* chamfer is the norm. Sometimes drivers are not very open-framed, and a cove-bit is very handy at opening transition to these areas. When using 1.5" thick material, this is compounded, and more of a tunnel is present before relieving the material. In this case, I used a cove-bit between the mounts, and then a 45* chamfer bearing bit ran amongst the coved recesses to produce what I attached below. Each case is independent and unique, but some require more than one bit for best results.
              • #23
                Chamfer, scallop, relieve, all mean the same thing:
                The goal is to remove material everywhere except the screw-mounts for the drivers.
                • #24
                  Great thanks
