Hi all - This is my first ever crossover attempt so I'm looking for feedback and to learn (and not make any terrible errors). I bought 4 of the buyout W130s-4 drivers and a couple tweeters to try and learn by doing. I made a sealed 12.5 liter prototype cabinet based on the T/S parameters I measured after burning in the drivers (using WinISD). I made a couple attempts at a crossover using PCD because that's what I'm the most familiar with. .
The first is crossed at 2400 Hz. Not sure if the values are visible on the schematics. Woofer: L2: 0.6 mH; C5: 11 uF; R7: 5.6 Ohm. Tweeter: C9: 12 uF; L9: 0.2 mH; C10: 50 uF; R15 2.0 Ohm; R 16: 2.2R.
The second is crossed at 2800 Hz. Woofer: L2: 0.5 mH; C5: 11uF; R7: 5.6 Ohm. Tweeter: C9: 9 uF; L9 0.2 mH; C10: 27 uF; R15: 2.4 Ohm; R16: 3.7 Ohm.
Any thoughts would be great. Hopefully I can get far enough to order the crossover parts and they'll be in stock.
Once I finish the TM, I plan on tearing it down and making a floorstanding MTM with basically the same crossover but with the woofers wired in series. Of course that's probably another month or two out.
