Just noticed new Dayton drivers are in stock. 8ohm, 4ohm.
New Dayton 6.5in Drivers - GF180-04/08 Glass Fiber
Originally posted by johnnyrichards View PostThe advertised response of the 4 ohm looks like they will require less BSC than most drivers. They would likely end up 80-82db when implemented, which is pretty much typical for 6-7" 2-ways.
"peak sensitivity" would be more accurate, that value is a sad joke if you define sensitivity as the average sensitivity through the useful passband. Using the metric PE have used for this driver, the RS180-8 is a 98dB sensitive driver.
PE needs to ditch the mismash of metric and imperial units. When all other units are in metric, use metric for volume as well. You'll find this will match up with any competent spec sheet.
Originally posted by johnnyrichards View PostThe advertised response of the 4 ohm looks like they will require less BSC than most drivers. They would likely end up 80-82db when implemented, which is pretty much typical for 6-7" 2-ways."I just use off the shelf textbook filters designed for a resistor of 8 ohms with
- 1 like
