I worded that question kind of strangely, but here is what I'm trying to do...
This thread: Two New Radio Faceplate Preamps... - Techtalk Speaker Building, Audio, Video Discussion Forum (parts-express.com)
describes a fairly decent little faceplate preamp that I'd like to use for my next radio project.
I tapped into every solder joint I could find and the only thing I find that switched on/off with the unit is the 2.6 volts that powers the screen backlight LED's (this is to trigger a time delay relay to turn on the amplifier a few seconds after the preamp unit)
I was hoping the USB would be switched as it is 5v and would work perfectly with the 5 volt time delay relay board I already have, but alas... it stays powered up even when the unit is off.
If I just throw a switch to turn on everything, it will erase the FM presets so I'd rather not do that.
My goal is to just have to turn on the preamp, and have it trigger something to turn on the amplifier.
So any ideas how I could use 2.6 volts (at probably fairly low amperage capability) to trigger another switching device? Some type of transistor circuit (easy hopefully) to trigger one of the time delay relay devices? That's above my knowledge base at this point.
Thanks for any ideas. Otherwise, I'm going to have to do what I've always done... have the preamp turn on/off by itself, and use a switch to turn on/off the amplifier section separately. Not the end of the world, but I'd love to move past this obvious band-aid if possible.
TomZ
TomZ
