Questions regarding Carmody's Sunflower Redux and OB/Dipoles in general.
  • Questions regarding Carmody's Sunflower Redux and OB/Dipoles in general.
    After a few DIY kit builds, a few more advanced builds based off of forum plans and a few homebrew tweaks, I'm at the point in my speaker life where I am now ready to begin the journey into the open baffle speaker world. Looking around for an easier starter project Paul's Sunflower Redux caught my eye, being both by a designer I am familiar with, cheaper, and fun-looking.
    But I have a few questions about them. First off, i can't tell from any of the literature on them if he built these with the 4 ohm or 8 ohm version of the RS225. Paul's own site: Paul Carmody's DIY Speaker Pages - Sunflower [Redux] (google.com) doesn't mention AT ALL, with the sole clue being that the picture he chose for the woofers is the 4 ohm version. HOWEVER in his HT Guide forum post, announcing the build, he lists a BOM that calls for the 8 ohm version: Sunflower Redux (htguide.com) . HOWEVER HOWEVER that BOM had many self-admitted mistakes first flush, is not widely published and is suspect therefore. I looked at his modeled impedance graphs to see if i could glean it from that, but the low-point in his graphs is 5 ohms, which is 2 more than the driver-low of 3 ohms for the 4ohm nominal one and 2 less than the 7 ohms for the "-8" version. Once again inconclusive.
    Second: I know these are not truly full open baffle, at a minimum because the woofer section is monopole. I am pretty OK with this though because of the wide-directivity nature of lower frequencies, the design simplicity and performance making this trade-off sensible and sacrificing little (unless there is something about open baffle bass that i don't get, I just figure a good monopole at lower frequencies will still pressurize the room just fine, and the room reflections that make dipoles so good are not really relevant at low frequencies - feel free to correct me). So then the design does into true dipole alignment for the mids, starting at the first XO centered at ~250 Hz. The power radiation match between the monopole configuration of the bass and the dipole configuration of the mids should be well matched, for the reasons i gave above. Most full BSC bass systems radiate too much power at the lower frequencies any way and the dipole mids should help match that power. But then i see the tweeter and I get worried: not only is he crossing over from a dipole mid into a mono-pole tweeter, he chose a tweeter known for its high directivity. This tweeter already has notable off-axis drop-off starting around 2500 Hz, which also happens to be the chosen cross-over point for this system. I would be afraid that with a flat on-axis response, the jump from a dipole mid config to a highly directive monopole tweeter would be a jarring one for power radiation. Linkwit'z LX521 and Orion both have rear tweeters, for example (Though the LXMini does not, but the full-range driver that operates in the tweeter frequency range IS dipole, most of the higher frequency content will be blocked from traveling fully in the negative Z axis direction by the driver motor/installation tube.) . TL;DR: is the use of a single(monopole) highly directive tweeter a substantial shortcoming of this design?
    Anyway - thanks for reading my book, and any help you can provide, even tangential to my questions, would be of great use!
    Always wanted to hear these. Love Paul's other builds (I've done several). Another one you may want to consider is the f15 build at decware using Lii full range driver. That is of course if you are into low power tube amps and high efficiency speakers. Really simple build and open baffle.
    Carbon13
      Originally posted by Mallowood View Post
      ​(unless there is something about open baffle bass that i don't get, I just figure a good monopole at lower frequencies will still pressurize the room just fine, and the room reflections that make dipoles so good are not really relevant at low frequencies - feel free to correct me)
      In my experience, there is definitely something about open baffle bass. It is much less efficient, but it minimizes the woofers resonance and has a very clean and natural sound.
      • Mallowood
        Mallowood commented
        Editing a comment
        Well crap. NOW I'm going to have to go full ob. On a tangent, i was thinking of scraping together an ob two way with dirt cheap drivers like hivi and grs. Given the inefficiency of open baffle bass, roughly what gain in sensitivity would you pick the wider to be over the mids highs? 3db, 6db?
      • Billet
        Billet commented
        Editing a comment
        My most recent project attenuates the mids and highs about 10 db to get a good response. I have used -12 db or more on previous projects. Unfortunately, I think OB bass is fairly room dependent. I have a smaller room and don't expect or desire room shaking bass. Your results may vary...
