Advantech Underlayment Board is Good Stuff . . .
  • Steve Lee
    I tested and posted my findings below, Sir.
  • Steve Lee
    Bevel2
Name:	Bevel Cut_2 - Advantech.JPG
    Bevel3
Name:	Bevel Cut_3 - Advantech.JPG
  • Steve Lee
    Coffee still has me up so I did a lot of router beveling of the driver holes and cabinet edges - none of this has been sanded - just routed and vacuumed/photos taken:
Name:	Bevel Cut_1 - Advantech.JPG
  • Steve Lee
    Don't be afraid to pick over the available stock at the store seeking interesting and finer grained pattern compositions in the material - here are some of my pieces awaiting employment in projects:
    Blah1
Name:	Advantech - SampleGrain_1.JPG
    Blah2
Name:	Advantech - SampleGrain_2.JPG
    Blah3
Name:	Advantech - BenchTop.JPG
    Last Blah
  • Steve Lee
    I didn't get to the round overs but I did cut a rebate/recess like you would for flush mounting drivers - I did this with a 3/4" carbide straight flute bit on the router bench - it cuts like butter, low dust mostly small saw chips - not at all like MDF, zero splintering and very nice looking patterns to the material construction disclosed by the smooth cut:
Name:	Recess Cut - Advantech.JPG
  • Steve Lee
    Tom - Getting the router speed and feed rate right will determine the quality of the cut but to your point about splintering, this stuff is not like OSB or cabinet grade plywood to work with at all.
    How-about I go up to the shop tonight and run some 3/8" round-overs and 3/4" straight flute cuts in a test piece of Advantech and report back? (It's raining here now).
  • tomzarbo
    Steve,
    I kind of like the look of that stuff. It looks a little bit like the 'grain' structure of Hempwood.
    I'm in the process of buying some of that for a baffle for a small two-way speaker. It resembles what you have in its physical look.
    I'm wondering what happens when you try to do a driver recess in that stuff? Splinter city?
    I like DJG's OSB cabinets too. I saw someone had made a cabinet out of OSB at one of the DIY Dayton get togethers a bunch of years back too.
  • johnnyrichards
    Originally posted by Steve Lee View Post
    I hate it guys - looks the world is changing back to the late 70'/80's . . .
    I hope not - I don't know how much more union busting and "trickle down" the middle class can handle.
  • Steve Lee
  • Blenton
    No can do. Not available anywhere close to me. Ok, pretty much EVERYTHING is unavailable around me right now. Too many people not sitting at home pretending like the world is going to end if they think about going outside the neat little boxes they've been painted in to...
  • Steve Lee
    aarond --> check this out --> https://sweets.construction.com/swts...935/821497.pdf
    It is much stiffer/denser/moisture resistance than OSB or plywood and is pressed together using Poly Urethane as the primary bonding agent - very stable and less dusty to work with.
    Last year I bought a 4' X 8' X 3/4" sheet for $32 from a nearby Lowes improvement center . . . now its $73 plus tax! https://www.lowes.com/pd/AdvanTech-F...4-x-8/50126556
    The backside with the black stamping on it can be sanded glass-smooth and remove the lettering/stamping quickly with a random orbital sander.
    Edge exposed baffle cuts with a view of the backs sanded clean/smooth -->
    Click image for larger version  Name:	Packrats_Progress 11-13-2021_02.JPG Views:	0 Size:	408.6 KB ID:	1478769
  • aarond
    Unfortunately, it has more than DOUBLED in price per sheet since I bought my current stock just a year ago . . . (Don't get me started .https://www.homedepot.com/p/Advantec...2405/202084475
    What are you paying for what size of sheet? It doesn't look like HD has any available within 100 miles of me.
    Can you shoot screws in the the edges and sides w/o an uncommon issues?
  • Steve Lee
    Nah . . . Some Minwax Poly shades black - I like the way advantech looks . . . https://www.amazon.com/polyshades-bl...lyshades+black
    Veneer?
  • TNA
    You might search Advantech, there are a few other posts.
    https://techtalk.parts-express.com/f...h-for-cabinets
    If you decide to veneer over Advantech, I suggest you add a layer of 6mm underlayment between the Advantech and the veneer. I have tried both methods.The veneer without the underlayment is not as smooth. If you leave a piece of the Advantech outdoors for awhile, it swells, which makes for an unstable veneer substrate.
