Use an instrumentation amplifier on a 2MHz balanced signal
  • Use an instrumentation amplifier on a 2MHz balanced signal
    hi, hoping someone here can help me!I'm trying to use a AD623 instrumentation amplifier on a 2MHz balanced signal. the parasitic capacitance of my IA is 10pF or just under 8k ohm at 2MHz... the equivalent series input impedance circuit is 0.06 -7957i according to what I calculated...I need the highest possible input impedance, so to cancel out the parasitic C may I put an inductor in parallel with it? I ask cause I haven't found schematics where that's done and google search hasn't led me to relevant articles, yet..cheers
    I think you would get better luck if you visit an Analog Devices discussion group - check their website for support links.
    https://duckduckgo.com/?q=Analog+Dev...=v231-1&ia=web
    Good luck, sir.
      I wouldn't use that part, it's only rated for 800kHz at unity gain
        Agreed. If this is a crucial application you'll want maybe a 20MHz unity gain BW part, at minimum.
        Francis
