Enclosure Size for RSS315HF-4 12 & SPA250
Do we ALL have more of those Harbor Freight flashlights lying around the house than we can shake a stick at?
Build thread. Notice I added wood blocks at each woofer screw position. IMO, they need some added thickness.
https://techtalk.parts-express.com/f...386714-new-2-1
Maybe get some bass shakers for your seat. The neighbors won't hear that..
Also, if you're getting rid of the pictured sub, and you can't turn the bass up, you might be very happy with the PE 8" Dayton 250DSP sub kit. I have two of them, one for my PC 2.1, and one for my LXmini 2.1 system.
https://www.parts-express.com/Powere...n-DSP-300-7150
This what it looks like now, but I am not done with the finish, it needs to be smooth out and polished
26Hz is 'Awesome Paste', I am not too interested in SPL(Lie) because I live in an old folks apartment village and cannot blast without a frontal assault from a brigade of Karen's (that I love and care for).
I have overcome this volume inadequacy by positioning the sub driver right next my cranium input orifice (ear).
You know, I will not be doing this until Spring and today I am starting to thinking that I don't want to change this box. It has sentimental appeal, I made it in '07 for a Cerwin Vega XL-12S that I still have but it needs a new surround kit.
I am going to put a creepy copper wire weave design on it and put the Cerwin Vega back into it and then give it away.
I am trying to figure out which is best, if this box has the right volume or more then I will use it, if more volume is better then I will build another box.
Originally posted by Xsserpxestrapx View PostHere is a question, with the RSS315HF-4 12 and the SPA 250 in a 2.218 cu. ft. box what length of 4" port would be best?
But I'd run with what Chris Roemer offered up. Put that port inside, it takes up ~0.15ft^3, yielding essentially the same result without the need for a subwoofer with giant tube sticking out of it.
Doesn't the port volume reduces the box volume? 20" of 4" tube is a lot of volume.
The box that I mentioned above had a 1 ft. - 4" external port
Francis, the box that I mentioned that I have from another build is the same size. Besides, I can save a lot making it myself and have a better box.
If you can fit a 4" port that's 20" long into your box (using elbows), you should end up near 2 cu.ft. net, w/an F3 near 30Hz and an output around 110dB (OUCH!).
That's w/the 250 unboosted. W/boost, you'd want to go about half that size, and closed.
A basic decision is sealed vs reflex. I like sealed best for music, but if you need to dig deep for home theater, or power a large room, reflex (include passive radiator here) has advantages.
PE has 10" and 12" sub kits with two passive radiators using the larger 500 watt dsp plate amp. One long time forum member recently built the 10" and was very pleased. I have two 8" kits using the 250 watt amp. It is very versatile, I recommend it especially for 2.1 systems where you can run pre out to the sub and loop back to main in on your amp.
