quite off topic - can you use any bolts from a hardware store as battery terminals on a 3.7-24v project? i saw something interesting to avoid soldering/welding terminals, but unsure what bolts could potentially be used or not.
quite off topic - can you use any bolts from a hardware store....
Any steel/brass/aluminium bolts will conduct electricity. Just avoid galvanised or anodised.Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
Refurbs: KLH 2 | Rega Ela Mk1
Originally posted by djg View Post
The excerpt from Boeing source material states, "CELL: BATTERY,NICAD,CVH250KA, Saft Batteries, Part # 023412-000=23 Mfr. Part # 023412-000
The 257CH-9 Saft nickel-cadmium battery consists of a box (020), containing 20 individual cells CVH250KA. These cells are connected in series to obtain 24 V nominal. Individual cells are enclosed in a polyamide container that provides insulation, allowing them to be fitted side-by-side in the battery box. Interconnection of cells is via rigid, highly conductive, nickel-plated copper links (180 to 240). Each link is held in place by nickel-plated copper nuts (130) on the cell terminals. Inside the battery box, individual cells are held in place by partitions, liners and spacers (040), and a cover (030). The terminals (050) connects the battery to the aircraft DC power. The cover (030), which can be removed, is attached to the box (020) by 4 latches."
The excerpt from Hawker source material states, "1.2.2.5 Pole terminals, connectors and terminal nuts
Pole terminals, nuts and connectors used for the inter-cell connection are made of highly conductive nickel-plated copper material."
PE Mods, please do not delete the following links to some example information related to nicad batteries used in certified aviation applications, on large transport aircraft. These links merely confirm material used in that application, are not SPAM and do not compete with anything that PE sells.
Boeing:
Shop Boeing for 023412-000, Saft Battery Cell, 24 V, 25 Ah, Nickel Cadmium, 25 A, 20 Cell, 3650 Days, KOH, Polyamide. Boeing offers Aircraft Parts, Chemicals, Tools, and more.
Hawker: https://www.enersys.com/49bd63/globa...ersion1_en.pdf"Our Nation’s interests are best served by fostering a peaceful global system comprised
Originally posted by 3rutu5 View Postquite off topic - can you use any bolts from a hardware store as battery terminals on a 3.7-24v project? i saw something interesting to avoid soldering/welding terminals, but unsure what bolts could potentially be used or not.
