Recommended crossover for this woofer/tweeter combo?
Off the shelf crossovers are NFG. Learn how to calculate your own with the appropriate software. You don't necessarily have to go 4th order, but I wouldn't do 2nd order either, especially when just one more cap to get 3rd order does so much better a job.
2nd order HighPass: 8uF series cap, then a 1.0mH shunt coil (to ground), then a 20ohm resistor to gnd. (in parallel w/the tweeter (or "across" its terminals)).
2nd order LP w/Zobel(thingy): Use a 0.60mH series coil, then a 10uF shunt cap, then Zobel: R = 5ohms + cap = 22uF.
Runs "flat" near 90dBv. Fc @ 2k. Solid 4ohm design.
If the tweeter's too loud, you can add resistance out front (amp side of HP filter) approx. 1ohm per dB (drop).
Paul Carmody's Classix II is sold as a kit here on Parts Express, details are also on his website
https://sites.google.com/site/undefi...ers/classix-ii
The BC25, a nominal 4 ohm tweeter, is used in many other projects; crossover point depends on the woofer or mid used. If the question is whether you can use the BC with a 4 ohm woofer, that will depend on your amp/receiver.
Geoff
Are there any examples of assembled ones here on PE you could show me? I was having trouble finding one that supports a 4 ohm tweeter.
+1, I've used it in three projects crossed between 2,000 and 2,500 Hz; it sounds comfortable there. Third, or in the case of Paul's Classix II, fourth order high pass.
Geoff
As low as you can, as the main problem with car speakers is off-axis response in the mids, because the midbasses are seldom near ear level. I'd say that tweeter would be comfortable at 2kHz with a third order high pass.
Peerless by Tymphany BC25TG15-04 1" Silk Dome Tweeter
https://www.parts-express.com/Peerless-BC25TG15-04-1-Silk-Dome-Tweeter-264-1040
Goldwood GW-S650/4 6-1/2" Poly Cone Woofer 4 Ohm
https://www.parts-express.com/Goldwo...-4-Ohm-290-308
They're going to be used as door speakers in my car.
Edit: All of this is completely new to me so any additional resources would be greatly appreciated.Last edited by Pounder; 01-20-2022, 01:57 PM.Tags: None
